| » Whirlpool Top loading washer will not fill |
Model Number: DSQ9633LWD Brand: Whirlpool Age: 5 - 10 years
My Whirlpool Top loading washer will not fill. I had a similar problem a couple of years ago and replaced the inlet valve (8181694), so I replaced it again, since we have very hard water. Problem still exists. I have verified that water is coming out of both hot and cold hoses. The washer will go into spin cycle. Where do I go from here?
The model number you posted does not come up. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
There is something wrong in the beginning of the model number too. Double check it please.
__________________
The model number GSQ9633LW0 is the correct one. Good job!
Most likely the problem is a bad ATC (water temperature) control board (inside the control panel) but there is a small chance for the temperature switch to be bad as well. I would replace the ATC board first. - The ATC board Part number: 3955728 - The temperature switch Part number: 3950358 Here are the breakdown diagrams and Parts for Whirlpool GSQ9633LW0 - AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Frigidair Front Loading Washer Fill and Cycle Problems | Capron09 | Washer Repair | 0 | 11-12-2010 04:09 PM |
| Whirlpool Front Loading Washer (code F-11) | GDOMB | Washer Repair | 1 | 10-22-2010 11:39 AM |
| Whirlpool Duet Front Loading Washer | GDOMB | Washer Repair | 3 | 10-22-2010 11:32 AM |
| Whirlpool top loading washer . | Jim's wife | Washer Repair | 1 | 08-31-2009 01:35 PM |
| The sticky up thing through the middle of a top loading Whirlpool washer | Julian | Washer Repair | 2 | 03-15-2009 04:57 AM |
