Discuss
Frigidaire frontloading washer leaving clothes wet not spinning during the spin cycl
 in
Washer Repair
we have a frigidaire fronloading washer, that sometimes the clothes are damp,and other times the clothes are soaked, ive checked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire frontloading washer leaving clothes wet not spinning during the spin cycl
  #1 (permalink)
Old 10-24-2012, 05:19 PM
Junior Member
Michaelsandy is on a distinguished road
Angry Frigidaire frontloading washer leaving clothes wet not spinning during the spin cycl
Brand: Frigidaire   Age: 5 - 10 years
we have a frigidaire fronloading washer, that sometimes the clothes are damp,and other times the clothes are soaked, ive checked all connections, everything seems ok,but before when it would spin it was really violent, now it sounds like its spinning but it isnt, i dont know the model number its rubbed most of the way off. we have had trouble with this washer since we have had it but we are trying to make it last
  #2 (permalink)
Old 10-25-2012, 04:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It's almost impossible to do any troubleshooting and/or find replacement parts without the model number. Check for the name plate on the door frame. Remove the front bottom access panel and check for an envelope with the tech sheet.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-25-2012, 05:55 PM
Junior Member
Unhappy model number
I found it on the warrenty card, the one behind the door is almost erased,
the model isFTF2140ES0, yesterday we kept get 3 beeps, but I read some other post today and tok the big hose off and found some change a bra underwire, but still will not spin even on the rinse cycle it will drain though, and will agaitate but thats as far as it will go
  #4 (permalink)
Old 10-25-2012, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check for any error code displayed as described in the tech sheet. If there is no error code displayed, run the Diagnostic test. Post the results.
Here are the breakdown diagrams and Parts for Frigidaire FTF2140ES0 Washer - AppliancePartsPros.com
__________________
  #5 (permalink)
Old 10-26-2012, 02:28 AM
Junior Member
Unhappy
yea the error beebs mean washer orver filled,or master control board and i dont know how to run the Diagnostic test, we have nothing that tells us how
  #6 (permalink)
Old 10-26-2012, 12:49 PM
Junior Member
Unhappy
ok this is what i got from the diagnostics
all of the lights flash 4 times with 4 beeps then the start button flashes an additional 2 times with no beeps
  #7 (permalink)
Old 10-26-2012, 01:02 PM
Junior Member
Default
I believe it is the comtrol board and I think its an E46 error
  #8 (permalink)
Old 10-26-2012, 04:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Per the tech sheet 4 & 2 corresponds to the error code E42 which means "the door remains locked after cycle is complete". Is this correct?
If yes then more likely the problem is a bad door switch/lock assembly.
- The door lock assembly Part number: 131763202
__________________
  #9 (permalink)
Old 10-26-2012, 06:41 PM
Junior Member
Default
no the door doesnt remain locked,
  #10 (permalink)
Old 10-26-2012, 06:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you undo the diagnostic test please?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Leaving Sopping Wet Clothes littlejon3 Washer Repair 0 05-27-2010 01:28 PM
Spin cycle leaving clothes soaking wet ctrauthwein@hotmail.com Washer Repair 1 03-16-2010 06:20 PM
Spin cycle leaving clothes soaking wet Bamaman31 Washer Repair 4 11-01-2009 05:07 AM
clothes washer wont spin, when I push down on the lid it starts spinning property manager Washer Repair 1 11-11-2008 11:04 AM
Washing Machine is leaving clothes smelling like mildew and leaving detergent on them Redskinsrhonda Washer Repair 1 09-19-2007 03:57 AM
