| » Epic Z Washer |
Model Number: MHWZ600TW Brand: Maytag Age: 1 - 5 years
I'm getting error codes F26, F22 and F28 (twice) before it ends diagnostics and then locks shut. I have tested the:
Inlet Valve Solenoids, PressureSwitch, Line Filter, Detergent Dispenser Motor & Switch , Drain Pump,Temperature Sensor & Heater, Drive Motor, and Interlock Switchs and all test withing spec. The door latch tests at 60 ohms from pins 2-3 and 120 ohms from pins 1-3. I have changed the CCU and MCU. This machine will not get past go. Please help this thing is driving me nuts. Ads By Google Related Models |
| Display Modes | |
| Maytag Epic Dryer | CSM Denny | Dryer Repair | 1 | 12-13-2011 06:49 AM |
| Epic Z gas dryer not getting as hot as it should | msugoalie | Dryer Repair | 1 | 06-25-2011 05:55 PM |
| Maytag Epic Z front load washer bellows replacement | Andrew M | Washer Repair | 0 | 03-16-2011 08:14 PM |
| maytag washer -epic z | misterfixall | Washer Repair | 2 | 04-16-2010 11:01 AM |
| Epic Z Washer F 24 Error | lcwolf | Washer Repair | 2 | 01-03-2010 06:45 PM |
