| » Whirpool Washer not aggitating/Spinning |
Model Number: GHW9100LW1 Brand: Whirlpool Age: 5 - 10 years
I discovered My Washer was not (washing) so I opened the back compartmentand I found the Driver belt had slipped off the driver Pulley, there was also alot of black dust that came from the belt rubbing against the drum. I purchaseda new belt and replace it, but the new one also slip off. After furtherexamination I notice the Pulley was Wobbly, so I removed the bolt to gain accessto the Pulley and notice it had some wear around the center where the boltlocks, which made it, wobble and not fit tightly. Now here is my question, if I replace this pulley, would this resolvemy problem? Or is there more to this issue, perhaps is damage bearing? That causedthe pulley to loosen, and then the belt to slide off. Single Mom trying to resolve this issue on my own. I will appreciatean honest knowledgeable answer. Ads By Google Related Models |
Hi.
Open the washer's door and see if you can move the basket up and down. If it moves freely then most likely the bearings are going bad. But we don't know how long the washer will run before breaks. You can return the part even if it has been installed. Here is the pulley Part number: 8182650 The belt Part number: W10388414 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Please do so.
Simon.
__________________
Hello Simon and Concern forum Comunnity
Im PLease to inform you that by replacing the driver belt and driver pulley my washer is working again. At least for now, as i suspect it probably will only give me another year or so, but Hey!! Not complaining! I want to thank Appliancepros.com for the quick shipping and delivery of my part! I give the an A+. |
You are very welcome.
Simon.
__________________
| Display Modes | |
| Whirlpool caprio agi not aggitating or spinning | otmom | Washer Repair | 0 | 10-10-2012 07:25 PM |
| Whirpool washer not spinning, desperately need your help please | dro53 | Washer Repair | 2 | 09-18-2012 05:41 PM |
| GE washer not aggitating or spinning 2 years ol | chandajean | Washer Repair | 1 | 12-12-2009 06:33 PM |
| admiral washer making gear loud noise when spinning or aggitating? | heidmann1 | Washer Repair | 3 | 10-02-2009 04:41 PM |
| washer not aggitating or spinning | ravensy2k | Washer Repair | 3 | 03-15-2008 09:10 PM |
