Discuss
maytag selective spin and pump out
 in
Washer Repair
washer work ok on regular cycle only. will not spin or pump out on the Wrinkle Control or Delicates cycles.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag selective spin and pump out
  #1 (permalink)
Old 10-24-2012, 07:57 AM
Junior Member
garybo is on a distinguished road
Default maytag selective spin and pump out
Model Number: MAV208DAWW   Brand: Maytag   Age: 5 - 10 years
washer work ok on regular cycle only. will not spin or pump out on the Wrinkle Control or Delicates cycles. If timer is then moved to the Exteneded Spin setting, it will spin and pump out the water. Timer work ok
Ads By Google
Related Models
Maytag MAV208DAWW WASHER-TOP LOADING
Admiral MAV2200AJW WASHER-TOP LOADING
Maytag MAV2755AJW WASHER-TOP LOADING
Maytag MAV2755AWW WASHER-TOP LOADING
Maytag MAV2757AWW WASHER-TOP LOADING
Maytag MAV275SAWW WASHER-TOP LOADING
Maytag MAV308DAWW WASHER-TOP LOADING
Admiral MAV3350AGW WASHER-TOP LOADING
Maytag MAV3757AWW WASHER-TOP LOADING
Maytag MAV3758AWW WASHER-TOP LOADING
Maytag MAV3855AGW WASHER-TOP LOADING
Maytag MAV3855AKW WASHER-TOP LOADING
Maytag MAV3855AWW WASHER-TOP LOADING
Maytag MAV385SAWW WASHER-TOP LOADING
Maytag MAV3905AWW WASHER-TOP LOADING
Maytag MAV3955EWW WASHER-TOP LOADING
Maytag MAV4057AWQ WASHER, ATLANTIS
Maytag MAV4057AWW WASHER, ATLANTIS
Maytag MAV408DAWK WASHER-TOP LOADING
Maytag MAV408DAWW WASHER-TOP LOADING
Maytag MAV4500AWW WASHER, ATLANTIS
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
  #2 (permalink)
Old 10-26-2012, 06:43 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since it will work on one cycle this suggests the timer is not ok and that it is the problem.
Try changing it out and see if that fixes things.
__________________
  #3 (permalink)
Old 10-26-2012, 07:07 PM
Junior Member
Default
I thot it was the timer too. So I changed it at $100 bucks and still have the problem.
  #4 (permalink)
Old 10-27-2012, 05:51 AM
Senior Expert
APP Volunteer
Default
The next likely suspect is the motor/wiring. It sounds like the motor will operate at one speed but not the other.
Sorry the timer did not fix things, but if you bought the timer from this site you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top loader will agitate and pump but won't spin Davidasmithpe Washer Repair 1 08-06-2012 04:49 PM
Maytag will not agitate,but will pump out and spin willnise Washer Repair 3 06-14-2012 01:14 PM
maytag top loader won't spin or pump brute Washer Repair 3 11-19-2009 06:10 PM
Maytag will agitate,spin, won't pump out water DealerMan Washer Repair 1 10-18-2009 07:51 AM
maytag will not spin agitate or pump drembo Washer Repair 7 12-25-2007 02:37 AM
