| » Epic Z- Door lock problem? |
Model Number: MHWZ400TQ01 Brand: Maytag Age: 5 - 10 years
Hey guys-
I'm hoping someone can help me or point me in the right direction. Problem: the washer goes through the cycle and freezes on the last minute. Its finished, the water drains, but the door on the washer won't unlock. The first problem code was F20- low or no water pressure. After many steps, I cleaned out the water intake in the back, yes, it was goobered up pretty badly. The door STILL won't unlock so I was just positive that the door lock mechanism was bad. I replaced it. STILL when I do the diagnostic cycle, it finishes at 'rinse and spin' meaning check door lock mechanism. I was able to put it through a 'rinse and spin' cycle, the water did fill the tub and drain out, but it still froze with one minute to go and the door didn't unlock. Do any of you guys have any ideas on where to go from here? Thanks for your help- I appreciate it! Christina Ads By Google Related Models |
Hi Christina,
Very likely the problem is a bad main control board (CCU). - The main control board Part number: W10205976 Here are the breakdown diagrams and Parts for Maytag MHWZ400TQ01 Washer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
Hi Christina,
I'm sorry to hear it. You already replaced all parts which could cause it. Check the wire harness between the door lock and the CCU. Make sure all connections are firm. If there is nothing wrong then you probably have to call a factory authorized tech. Gene.
__________________
| Display Modes | |
| Door Lock / Unlock Problem | mceagle | Washer Repair | 1 | 10-06-2011 06:48 PM |
| Kenmore Oven problem - lock engaged & door is stuck open. | lcastle14 | Oven Repair (including Ranges and Cooktops) | 3 | 03-09-2011 02:03 AM |
| Kitchen Aid Self Clean Problem With Door Lock | Dexter Adderley | Oven Repair (including Ranges and Cooktops) | 0 | 11-06-2010 07:55 AM |
| Washer door lock problem | rnigel | Washer Repair | 2 | 07-18-2009 07:26 AM |
| Duet door lock problem | Fixshannon | Washer Repair | 0 | 09-14-2007 08:20 AM |
