| » Kenmore Brake and Drive tube removal |
Model Number: 110.92593210 Brand: Kenmore Age: More than 10 years
On my 16 yr old Kenmore direct drive washer, at the bottom of the cam tube is a groove that holds the retaining ring or C clip. The groove is worn. The retaining ring just falls out so I guess I have to replace the cam tube. In order to replace the tube I figure I have to remove the agitator, then turned the washer on it's side and removed the motor-pump-transmission assembly. It appears you also have to remove the spanner nut. My question is: Do you have to remove the enclosure, the plastic tub, and then the basket to remove the cam tube ? So, can I just remove the spanner nut and just slide out the cam tube assembly without having to remove the enclosure, tub and basket ? Please advise. Thank you
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Replacing direct drive washer brake shoes | richappy | Washer Repair | 38 | 03-06-2013 03:11 PM |
| Brake removal | homie12960 | Washer Repair | 1 | 02-03-2010 05:04 PM |
| Whirlpool belt drive washer has brake noise when stopping | macirion | Washer Repair | 0 | 08-08-2009 04:43 PM |
| Direct drive washer brake | yurman | Washer Repair | 1 | 08-02-2009 04:35 AM |
| Replacing direct drive washer brake shoes | richappy | Forum Announcements | 0 | 02-28-2009 07:38 AM |
