Discuss
Frigidaire Washing Machine
 in
Washer Repair
Hello, I have been having trouble with my washing machine. Orginally, it started to turn on without touching it at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Washing Machine
  #1 (permalink)
Old 10-22-2012, 07:59 AM
Junior Member
wshaffer is on a distinguished road
Default Frigidaire Washing Machine
Model Number: LTF2940ES3   Brand: Frigidaire   Age: 5 - 10 years
Hello,
I have been having trouble with my washing machine. Orginally, it started to turn on without touching it at all, then if you tried to do something it would give the error code ERR. Once this started to happen, we did the diagnostic test and it gave us the error code E41, and the Tech Data Sheet says the control board thinks the door switch is open. If we unplugged the Washer and turned the dial to touch-up (the starting position) it would then work again for a cycle or two, but then do the same thing.
A few times it also got stuck in the middle of a cycle, or would be frozen on 1, and not complete the entire cycle. It would give the command PAU and if you tried to do anything, it would say ERR.
Now, I cannot get it to do anything, I plug the washer in and the LED screen is Blank, but all the Little LEDS are lit up under the options, cycle, water temp, etc. buttons. It will also flash PAU but I cant even clear that code anymore. I am still confused if this is the door switch assembly or the control board? Also, if it is the control board, is it the electronic control up top or the motor control board underneath the machine?
Thanks and hope to hear soon!
Bill
Ads By Google
Related Models
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
Whirlpool LVA5565W0
Whirlpool LVA5565W1
Whirlpool LVA6300W0
Whirlpool LVA6304W0
Whirlpool LVA6305W0
Whirlpool LVA6309W0
Whirlpool LVA6400W0
Whirlpool LVA6400W1
Whirlpool LVA6404W0
  #2 (permalink)
Old 10-23-2012, 06:04 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Try replacing the main control unit, the one at the top. These electronic controlled machines are difficult to diagnose, and sometimes the door switch can be the issue but your problem really sounds like the main control unit.
__________________
  #3 (permalink)
Old 10-24-2012, 04:01 AM
Junior Member
Default
Quote:
Okay, thats what I was thinking too! Thanks
  #4 (permalink)
Old 10-24-2012, 06:45 PM
Senior Expert
APP Volunteer
Default
Good, let us know how it turns out. If you buy from this site and the part does not fix the problem you can return it, even a control unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gallery washing machine Pechols Washer Repair 1 04-03-2012 11:08 AM
Frigidaire washing machine Tracy0914 Washer Repair 0 06-21-2011 10:56 AM
Frigidaire washing machine monicaowen Washer Repair 1 09-30-2009 07:46 AM
frigidaire washing machine kimjkenyon Washer Repair 1 06-14-2009 04:32 PM
Frigidaire washing machine vibrations sundevil99833 Washer Repair 0 09-07-2007 11:22 AM
