Discuss
Admiral Washer Spin Cycle problem
 in
Washer Repair
Greetings, I have an Admiral Designer Series washer that is somewhere between 5 and 10 years old (donated by a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Admiral Washer Spin Cycle problem
  #1 (permalink)
Old 10-21-2012, 09:15 AM
Junior Member
nckomorowski is on a distinguished road
Default Admiral Washer Spin Cycle problem
Brand: Admiral   Age: 5 - 10 years
Greetings,
I have an Admiral Designer Series washer that is somewhere between 5 and 10 years old (donated by a friend). For the past month it has had a problem with the spin cycle. The washer will fill and agitate just fine, but it will not spin except after the extra rinse of the regular/permanent press cycle. This means that when I do a wash, I wait for the fill and agitate to finish and then I turn the knob to the spin after the extra rinse. After that completes I have to move it back to the rinse cycle and again to the spin afterwards.
When using the spin, I have to pull the knob out and hold it for a few seconds to make sure it continues spinning and on occasion I have to rotate the knob a click or two in order for the spin to work.
This issue is quite frustrating as I have to babysit the laundry. Any help would be appreciated.
Nick
Ads By Google
  #2 (permalink)
Old 10-23-2012, 05:53 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since it will work mechanically this suggests a problem with the timer. Use your model number to order a timer, and if you order from this site and the part does not fix the problem you can return it.
I think it is highly likely that a new timer will do the job.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Washer won't do spin cycle Amanda.Wolz Washer Repair 0 04-10-2012 01:07 PM
Admiral washer agitates during spin cycle Trenchfoe Washer Repair 1 03-05-2012 06:07 PM
Admiral washer agitates during spin cycle Trenchfoe Dishwasher Repair 0 03-03-2012 10:58 PM
Admiral washer-spin problem- balance? belt? krferm Washer Repair 3 08-17-2010 04:26 AM
Admiral Washer Spin Cycle Not Working achetwood Washer Repair 3 12-17-2007 06:44 PM
