| » Whirlpool washer spinning problem |
Model Number: LSR9434PQ1 Brand: Whirlpool Age: 1 - 5 years
This Whirlpool is having intermittant spinning issues on the rinse cycle. Sometimes it spins, sometimes it doesn't. If it doesn't spin and I reach in and turn the drum once by hand and shut the door quickly that will get it going. Is a part going bad or getting worn out?
Could be the clutch or basket drive block. You need to remove the cover, bypass the lid switch and observe the clutch housing during spin. If the clutch housing is spinning but the basket drive tube is not, the clutch is slipping. If the basket drive tube is spinning but the basket is not, the drive block is bad or the spanner nut may be loose or the end of the drive tube is damaged. Since you can get it spinning, it is more likely to be a slipping clutch.
Eric |
| Display Modes | |
| Whirlpool washer not spinning | richandtru70 | Washer Repair | 0 | 05-22-2012 09:31 AM |
| Whirlpool Washer: not spinning | RTPM | Washer Repair | 5 | 08-22-2011 09:03 AM |
| Problem with Whirlpool washer not draining or spinning out | mywhirlpool | Washer Repair | 1 | 06-10-2011 02:30 PM |
| Whirlpool Washer not spinning | A1adventures | Washer Repair | 1 | 10-31-2009 06:41 AM |
| Amana washer Bearing and Spinning problem | papabear1245 | Washer Repair | 1 | 05-31-2009 10:26 AM |
