Discuss
Removing cabinet from Kenmore stacked waser dryer
 in
Washer Repair
My washer is leaking water from the front . I want to remove the cabinet to see if I can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Removing cabinet from Kenmore stacked waser dryer
  #1 (permalink)
Old 10-20-2012, 02:25 PM
Junior Member
northman is on a distinguished road
Default Removing cabinet from Kenmore stacked waser dryer
Model Number: 110 92972102   Brand: Kenmore   Age: 5 - 10 years
My washer is leaking water from the front . I want to remove the cabinet to see if I can find the problem. It is a stacked washer dryer combo and all I can find on the internet are cabinet removal for standard washers. Can anyone help me out here?
Thanks!!!!
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 10-20-2012, 04:15 PM
Junior Member
KnightKnight is on a distinguished road
Default Tooo Funny!!!
Wow!
ok, I was starting to feel like a yoyo. I have been looking for this same information now for over a week. I just don't want to tear the cabinet up. Oh yea mine is model number 41791702001 I imagine they are the same.
Any help is a great Mahalo!
  #3 (permalink)
Old 10-20-2012, 06:58 PM
Junior Member
appliance dude is on a distinguished road
Default
You should see two big phillip screws on the bottom of the washer. Take these off and slide the front panel down and then pull it off.
  #4 (permalink)
Old 10-21-2012, 08:01 AM
Junior Member
Default
Quote:
Sorry but there are no screws that I can see on the bottom of the of this washer. At least none that I can get to. Am I missing something here?
  #5 (permalink)
Old 10-21-2012, 08:56 AM
Junior Member
Default
Quote:
Did you change your model number? I thought it started with 417? 417 = frigidaire, 110 = whirlpool. Take the slanted panel off in the front between washer and dryer. Then there will be two screws holding the top on in the back. Slide top forward and set aside. There will be wires hanging off of it for lid switch so be careful. Then there will be two screws holding front panel on at top. Remove those and lift panel up and it will come off. You are then free to check washer out. This being a whipool washer I would check the drain pump first which is on the left front. They are very famous for leaking.
  #6 (permalink)
Old 10-21-2012, 11:46 AM
Junior Member
Default
No I didn't change my number that was the other guy's model number that replied to my posting.
Mine is 110.
I took the slanted cover off and removed the two screws, this setup seems to be different that what you described. There seems to be more to it as there are two clip like devives holding the top on that I can't get off.
Hopefully this photo will help.
Thanks!
  #7 (permalink)
Old 10-21-2012, 03:03 PM
Junior Member
Default
Mine is 110.
Thanks!
I will look at a break down tomorrow and get back with you.
  #8 (permalink)
Old 10-22-2012, 05:09 AM
Junior Member
Default
Thanks, I really appreciate it.
  #9 (permalink)
Old 10-22-2012, 10:20 AM
Junior Member
Default
Ok you need to pry the two brass colored clamps off. Get a flat tip screwdriver and stick it in the hole the clamp snaps in. Catch the lip of the clamp and push the screwdriver back. It should come unsnapped. The lid should slide forward then. The front panel should have 2 screws holding.
  #10 (permalink)
Old 10-22-2012, 01:06 PM
Junior Member
Default
Thanks, that was a big help. There was 4 screws on this one two on top and two on the very bottom and I mean bottom. Luckily I have long arms. LOL Of course the top two were facing screw side towards the outside and the bottom were reversed and I couldn't get a socket on them and had to use a wrench a 1/4 of a turn at a time.
Now I see a pump in the front and that's where i was leaking . What do I do now?
Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 98702 Stacked Washer/Dryer won't spin flashpipe Washer Repair 1 04-22-2011 12:39 PM
removing cabinet edclc Washer Repair 1 01-08-2011 04:32 PM
Replacing heating element in Kenmore stacked dryer LLesniak Dryer Repair 1 02-04-2010 06:14 PM
Removing cabinet from Kenmore washer bingo9294 Washer Repair 1 10-27-2009 03:45 PM
Removing dryer cabinet to repair igniter Mikeofba Dryer Repair 1 07-27-2007 10:48 PM
