Discuss
Agitator Bolt & Washer Question (with Pictures)
 in
Washer Repair
First of all thanks to those of you have already offered suggestions / tips. However, I am re-posting this as
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator Bolt & Washer Question (with Pictures)
  #1 (permalink)
Old 10-18-2012, 03:48 PM
Junior Member
mtnbiker3000 is on a distinguished road
Default Agitator Bolt & Washer Question (with Pictures)
Model Number: LSR7233DQ1   Brand: Whirlpool   Age: More than 10 years
First of all thanks to those of you have already offered suggestions / tips. However, I am re-posting this as my parts are coming in tomorrow and I want to reassemble. I need clean clothes!!
I have a question about the agitator bolt and rubber washer that I pulled out. When I took it out, there were two rubber washers on it. One small, beveled washer that fits snug on the threads of the bolt (left of pic). And another wider, flatter washer that almost pulls over the top of the bolt head - doesn't seem to fit right (center of pic).
When I bolt it back down, the bigger washer doesn't seem to seat right, and if I don't hold it in place with a screwdriver, it will twist and pop out over the top of the bolt. Even when it stays on, it doesn't look like it would properly seal anything.
I bought a new flat washer from Lowe's (on the far right of photo) that fits nicely under the head of the bolt and seems like it would work better.
Why are there two rubber washers on one bolt? I inherited this washer from a family member, but I don't think anyone has ever pulled the agitator bolt before, so I believe it is stock…
Again, the two washers on the left were on the bolt when I took it out of the agitator assembly. Is this correct? Why?
UPDATE:
Well, not sure if this is correct, but the larger washer seems to fit perfectly at the joining points between the upper and lower agitator. Is this correct?
Also, does anything need greasing upon re-assembly??
And lastly... Kind of a noob question, but I should be able to spin the basket by hand correct? Didn't try real hard, but when I gave it a little push by hand, it didn't move. Will try again when I get home from work...
Thanks all!!!!!
Ads By Google
Related Models
Whirlpool LSR7233DQ1
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
  #2 (permalink)
Old 10-18-2012, 04:50 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Don't know firsthand but here is the parts breakdown for the agitator.
#2 is screw and washer, #24 is inner cap seal, #11 is agitator seal and the part you have placed the washer on in your pic is #22 thrust spacer.
Eric
  #3 (permalink)
Old 10-19-2012, 08:01 AM
Junior Member
Default
OK, got it sorted out! Looks like the TWO washers on the left of photo 1 used to be ONE washer. Over time, that washer broke into two pieces... Need a new washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stripped agitator bolt on transmission late arrival Washer Repair 1 07-26-2012 04:48 PM
Agitator Bolt SirTreek23 Washer Repair 6 02-21-2011 08:59 PM
agitator bolt washer fixster Washer Repair 0 06-29-2010 12:05 PM
GE Agitator came off - how to access bolt to re-install TopBob Washer Repair 1 07-13-2009 04:55 PM
How to remove agitator on newer GE washer which does not have bolt or scre at top. lba Washer Repair 0 12-29-2008 09:43 AM
