Discuss
Mav3358aww
 in
Washer Repair
Washer operates normally on regular cycle. Will not agitate or spin on delicate cycle. I replaced the timer with no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Mav3358aww
  #1 (permalink)
Old 10-18-2012, 01:40 PM
Junior Member
8romans28 is on a distinguished road
Default Mav3358aww
Brand: Maytag   Age: 5 - 10 years
Washer operates normally on regular cycle. Will not agitate or spin on delicate cycle. I replaced the timer with no response.
Ads By Google
  #2 (permalink)
Old 10-20-2012, 05:51 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Replacing the timer almost always fixes this, because if it works on one cycle that means there are not mechanical problems.
So if replacing the timer did not fix things it sounds like you have a motor or wiring problem, that the motor will not operate at low speed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
