mzbean06
#1 Posted : Thursday, September 24, 2009 12:07:11 PM(UTC)
mzbean06
my washer won't stop filling up. I think its the water level switch. could it be electrical? when i wiggle it it kicks off. Please help i don't know what part to order????
sidfink43
#2 Posted : Friday, September 25, 2009 4:05:04 PM(UTC)
sidfink43
I am assuming that the water will cut off if you shut off the machine or unplug it.
Before buying parts first check to make sure the plastic tube from the water pressure switch is not obstructed. Take out the two screws that hold the console to the cabinet and you will see the water pressure level switch and take off the plastic tube connected to it and blow it out.
If this does not fix the problem, here is the part
Part number: AP3890867
maytag washer won't stop filling up (Washer Repair)
by aswright33 7/13/2014 11:15:42 AM(UTC)
Frigidaire Washer Won't Stop Filling Up (Washer Repair)
by hntpilcher 2/23/2012 12:59:23 PM(UTC)
by craigwebster375 7/25/2011 3:23:21 PM(UTC)
Washer won't stop filling up (Washer Repair)
by CarlaS 2/22/2011 7:50:19 AM(UTC)
Admiral washer won't stop filling up with water! (Washer Repair)
by imcrazy73 2/9/2008 11:39:50 AM(UTC)
washer won't stop filling up on any water levels. (Washer Repair)
by danielle92273@yahoo.com 1/22/2008 2:42:39 PM(UTC)
