Discuss
Maytag washer SUD and F02 code - bad pump?
 in
Washer Repair
Hi All, I have a Maytag front load washer - model mfw9700sq1. I keep getting SUD and F02 (drain) codes.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer SUD and F02 code - bad pump?
  #1 (permalink)
Old 10-17-2012, 03:01 PM
Junior Member
hammy380 is on a distinguished road
Default Maytag washer SUD and F02 code - bad pump?
Model Number: mfw9700sq1   Brand: Maytag   Age: 1 - 5 years
Hi All,
I tried cleaning the drain catch, in which was only 6 coins.
I'm still getting the errors.
When i get the drain error.
I hit stop and restart the washer and it pumps out the water fine.
As if there were no problem.
Not sure if the pump is bad, maybe timing out or something?
Just want to make sure there isn't anything else to try before buying a new pump.
I read one thing online about a pressure switch for the SUD error?
Any ideas?
Thank you so much
Ads By Google
Related Models
Whirlpool MFW9700SQ1 Automatic Washer
Maytag MFW9700SQ1 Automatic Washer
Maytag MFW9800TK0 Automatic Washer
Maytag MFW9800TQ0 Automatic Washer
Maytag MFX100PAVS Washer - Top Loading
Maytag MFX50NNATS Washer - Horizontal Axis
Maytag MFX50PNAVS Washer - Horizontal Axis
Maytag MFX75PNAVS Washer - Top Loading
Maytag MFX80PNAVS Washer - Top Loading
Maytag MFX95PNAVS Washer - Top Loading
Whirlpool MG2070XAB0
Whirlpool MG2070XAQ0
Thermador MG29EAP
Whirlpool MG3090XAB0
Whirlpool MG3090XAQ0
Whirlpool MG3090XBB0
Whirlpool MG3090XBQ0
Whirlpool MG8120XDB0
Whirlpool MG8120XDQ0
Maytag MGC5430ADB Surface Unit - Gas
Maytag MGC5430ADC Surface Unit - Gas
Maytag MGC5430ADQ Surface Unit - Gas
Maytag MGC5430ADW Surface Unit - Gas
Maytag MGC5430BDB Surface Unit - Gas
Maytag MGC5430BDQ Surface Unit - Gas
Maytag MGC5430BDS Surface Unit - Gas
Maytag MGC5430BDW Surface Unit - Gas
Maytag MGC5536BDB Surface Unit - Gas
Maytag MGC5536BDQ Surface Unit - Gas
Maytag MGC5536BDS Surface Unit - Gas
Maytag MGC5536BDW Surface Unit - Gas
Maytag MGC6430BDB Surface Unit - Gas
Maytag MGC6430BDW Surface Unit - Gas
Maytag MGC6536BDB Surface Unit - Gas
Maytag MGC6536BDW Surface Unit - Gas
Whirlpool MGD5570TQ0 29" Gas Dryer
Maytag MGD5570TQ0 29" Gas Dryer
Maytag MGD5570TQ1 29" Gas Dryer
Whirlpool MGD5591TQ0 29" Gas Dryer
Maytag MGD5591TQ0 29" Gas Dryer
Whirlpool MGD5600TQ0 29" Gas Dryer
Maytag MGD5600TQ0 29" Gas Dryer
Maytag MGD5600TQ1 29" Gas Dryer
Whirlpool MGD5620TQ0 29" Gas Dryer
Maytag MGD5620TQ0 29" Gas Dryer
Maytag MGD5620TQ1 29" Gas Dryer
Whirlpool MGD5621TQ0 29" Gas Dryer
Maytag MGD5621TQ0 29" Gas Dryer
Whirlpool MGD5630TQ0 29" Gas Dryer
Maytag MGD5630TQ0 29" Gas Dryer
Maytag MGD5630TQ1 29" Gas Dryer
Whirlpool MGD5640TQ0 29" Gas Dryer
Maytag MGD5640TQ0 29" Gas Dryer
Maytag MGD5640TQ1 29" Gas Dryer
Maytag MGD5700TQ0 29"gas Dryer
Maytag MGD5700TQ1 29" Gas Dryer
Whirlpool MGD5707TQ0 29" Gas Dryer
Maytag MGD5707TQ0 29" Gas Dryer
Maytag MGD5707TQ1 29" Gas Dryer
Whirlpool MGD5720TQ0 29" Gas Dryer
Maytag MGD5720TQ0 29" Gas Dryer
Whirlpool MGD5721TQ0 29" Gas Dryer
Maytag MGD5721TQ0 29" Gas Dryer
Whirlpool MGD5730TQ0 29" Gas Dryer
Maytag MGD5730TQ0 29" Gas Dryer
Whirlpool MGD5740TQ0 29"gas Dryer
Maytag MGD5740TQ0 29"gas Dryer
Maytag MGD5740TQ1 29" Gas Dryer
Whirlpool MGD5770TQ0 29" Gas Dryer
Maytag MGD5770TQ0 29" Gas Dryer
Maytag MGD5770TQ1 29" Gas Dryer
Whirlpool MGD5800TW0 29"gas Dryer
Maytag MGD5800TW0 29"gas Dryer
Maytag MGD5800TW1 29" Gas Dryer
Maytag MGD5801TW0 27" Gas Dryer
Whirlpool MGD5805TW0 29"gas Dryer
Maytag MGD5805TW0 29" Gas Dryer
Maytag MGD5805TW1 29" Gas Dryer
Whirlpool MGD5820TW0 29"gas Dryer
Maytag MGD5820TW0 29"gas Dryer
Maytag MGD5820TW1 29" Gas Dryer
Whirlpool MGD5821TW0 29" Gas Dryer
Maytag MGD5821TW0 29" Gas Dryer
Whirlpool MGD5830TW0 29"gas Dryer
Maytag MGD5830TW0 29" Gas Dryer
Maytag MGD5830TW1 29" Gas Dryer
Whirlpool MGD5840TW0 29" Gas Dryer
Maytag MGD5840TW0 29" Gas Dryer
Maytag MGD5840TW1 29" Gas Dryer
Whirlpool MGD5870TW0 29" Gas Dryer
Maytag MGD5870TW0 29" Gas Dryer
Maytag MGD5870TW1 29" Gas Dryer
Whirlpool MGD5900TW0 29"gas Dryer
Maytag MGD5900TW0 29" Gas Dryer
Maytag MGD5900TW1 29" Gas Dryer
Whirlpool MGD5920TW0 29" Gas Dryer
Maytag MGD5920TW0 29" Gas Dryer
Whirlpool MGD5921TW0 29" Gas Dryer
Maytag MGD5921TW0 29" Gas Dryer
Whirlpool MGD6300TQ0 29" Gas Dryer
Maytag MGD6300TQ0 29" Gas Dryer
Whirlpool MGD6400TB0 29"gas Dryer
Maytag MGD6400TB0 29"gas Dryer
Whirlpool MGD6400TQ0 29"gas Dryer
Maytag MGD6400TQ0 29"gas Dryer
Maytag MGD6600TQ0 29" Gas Dryer
Whirlpool MGD9600SQ0 Gas Dryer
Maytag MGD9600SQ0 Gas Dryer
Whirlpool MGD9700SB0 Gas Dryer
Maytag MGD9700SB0 Gas Dryer
Whirlpool MGD9700SQ0 Gas Dryer
Maytag MGD9700SQ0 Gas Dryer
Maytag MGD9800TB0 Gas Dryer
Maytag MGD9800TK0 Gas Dryer
Maytag MGD9800TQ0 Gas Dryer
Maytag MGDZ400TQ1 27" Gas Dryer
Maytag MGDZ400TQ2 27" Gas Dryer
Maytag MGDZ600TB1 27" Gas Dryer
Maytag MGDZ600TB2 27" Gas Dryer
Maytag MGDZ600TK1 27" Gas Dryer
  #2 (permalink)
Old 10-19-2012, 05:25 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would try a new pressure switch. If you buy from this site and the part does not fix the problem you can return it.
__________________
  #3 (permalink)
Old 10-20-2012, 02:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
It may pump water out OK without an error after a restart because it is not monitoring the time it takes to pump out.
The error is it thinks it is taking too long to pump out.
Another thing I would try is remove the drain hose and check it.
Depending on what detergent and fabric softener you are using it could be growing gunk in the drain hose and restricting the water flow.
__________________
  #4 (permalink)
Old 10-20-2012, 04:27 AM
Junior Member
Default
Thank you Sidfink and Denman. I appreciate your input. I already have a pump on order. When it comes in, I will replace it and remove the drain hose and check. I will also double check the hose for the pressure switch. If I still have the problem, I will replace the pressure switch.
I will repost what worked.
Thanks again
  #5 (permalink)
Old 10-20-2012, 05:49 PM
Senior Expert
APP Volunteer
Default
Great, let us know how it turns out.
__________________
  #6 (permalink)
Old 10-27-2012, 02:58 AM
Junior Member
Default
Hi Guys,
Well here's the scoop.
I received my new pump.
I ripped out the old pump and drain hose completely out.
When I removed the drain hose from the back of the pump, I found a penny in there by the impeller.
I ran water through both drain hoses, finding no build-up inside.
I reassembled all, using the new pump.
I also reseated the connector for the pressure switch, at the switch and into the control module.
So far, we have done at least 10 loads of laundry.
We have not had 1 error code yet.
Previously, we would get a code on every single load.
So, in hind sight, I wish i removed the penny I found, then reassembled, not touching or replacing anything else, to see if that was the cause.
I have no idea if my pump was going bad, or it was the penny, or reseating the switch connectors, or combination of all.
My old pump, may still be good for all I know.
I'm not feeling ambitious enough to try and reinstall the original pump to find out.
Its working, so I'm going to leave well enough alone.
I'll keep the pump, just in case I may need it someday.
Thanks for your help!!
  #7 (permalink)
Old 10-27-2012, 05:54 AM
Senior Expert
APP Volunteer
Default
Great, sounds like Denman was right on about this one.
Don't think about it as having bought a part you may not have needed, think about it as having saved hundreds from a service call.
Thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer pump out problem. ritewaykay Washer Repair 1 04-18-2012 06:07 PM
I think the pump quite on my maytag performa washer ChevyCowboy Washer Repair 1 12-10-2011 07:15 AM
Maytag washer - replace belts or pump? mzpatti Dishwasher Repair 0 11-28-2011 02:07 PM
Maytag washer leaking, Seems to come from Pump mikou Washer Repair 2 11-11-2009 06:23 PM
Maytag washer belt/pump dpm6264 Washer Repair 1 11-03-2007 09:05 AM
