| » mvwc6esww1 washer fills with water close to s |
Model Number: mvwc6esww1 Brand: Maytag Age: 1 - 5 years
maytag fills with water close to spin cycle and stops 4 out of 10 times cant get it to move on for a period of time repairman replaced timer did not fix
I'm afraid I did not get it clear. Can you explain it more detailed please.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
washer works fine till it gets ready to rinse and spin then sometimes it stops, if you try to move to diff spin cycle its just dead. then after a peiod you might turn on and it will take off and finish. it might run 2 or3 loads fine before it dose it again
Remove the washer cabinet. Locate the pressure hose (#21 at the diagram) connected to the outer tub. Make sure it is clean and not twisted or pinched. The other end of the hose should be connected to the switch in the control panel. Disconnect it there and blow some air through the hose.
__________________
| Display Modes | |
| Washer only fills with hot water, no water during rinse cycle | rcmedrec1 | Washer Repair | 1 | 08-05-2011 06:28 PM |
| Washer fills with water and that's it | marylousnews | Washer Repair | 3 | 10-12-2010 11:22 PM |
| washer fills with water when off | hidon | Dishwasher Repair | 1 | 05-29-2010 03:56 AM |
| Washer fills with water and then nothing | mamabotanica | Washer Repair | 1 | 08-06-2009 09:32 AM |
