Discuss
Washing machine turning cold h20 into hot
 in
Washer Repair
When I put my washing machine on cold/cold, the machine pulls and fills water from the cold side and I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing machine turning cold h20 into hot
  #1 (permalink)
Old 10-15-2012, 05:58 PM
Junior Member
Kelbel248 is on a distinguished road
Default Washing machine turning cold h20 into hot
Brand: -brand-   Age: 1 - 5 years
When I put my washing machine on cold/cold, the machine pulls and fills water from the cold side and I felt the hose to make sure it was cold water going in---it is. But whenever I open the washing machine after the load cycle finishes its steaming hot...like burn your face hot and the water and clothes are super hot too. I'm at a loss because the water is cold going in, but then ends up steaming hot?!?!?! Please help!
Ads By Google
  #2 (permalink)
Old 10-16-2012, 07:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-21-2012, 06:38 PM
Junior Member
Default
Whirlpool
WFW9250WW00
  #4 (permalink)
Old 10-22-2012, 02:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the rear panel. Check the temperature sensor. Check the heater. Check for continuity between each of the heaters terminals and the ground. All instructions are attached. If there is nothing wrong replace the CCU.
- The temperature sensor Part number: 8181705
- The heater assembly Part number: 8182666
- The CCU Part number: W10299981
Here are the breakdown diagrams and Parts for Whirlpool WFW9250WW00 Washer - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Series 90 Kenmore washing machine NO COLD WATER Char H Washer Repair 1 05-10-2012 09:32 PM
Problem with cold water fill hose on washing machine. Need2WashMyClothesplzthx Washer Repair 1 12-11-2010 05:29 PM
No cold water in washing machine bandcamp Washer Repair 0 09-18-2010 07:41 AM
Kenmoore Front loader Washing machine - making alot of noise went washing ToddScott Washer Repair 1 09-11-2010 05:23 PM
No Cold Water in Washing Machine Biskiii Washer Repair 1 04-06-2009 03:30 PM
