Agitator does not function. Fills, spins and drains normally. Motor shows no fault codes (1 second blink when idle, 1/2 second blink when on). Motor makes no movement when in agitate cycle.
Groups: Expert
Need to check for AC voltage at connector C4 (rightmost) on inverter. Place one lead of voltmeter at white/red wire (neutral) of leftmost connector. For slow speed agitate you should have 120VAC at C4 yellow and black wires. For high speed, at C4 blue and black wires. These are the control signals from the control panel to put the inverter into the proper mode of operation.
This may be beyond your capabilities. Do not touch the motor casing as it is not at ground potential.
Eric
