Hi, The other day there was a problem with the transformer that supplies electricity to the house and the power was fluctuating wildly. The next time I tried the easher it wouldn't turn on. The door light comes on, but there's otherwise its's as if it was unplugged. I tested with a voltmeter and there is 122 volts to the control board in the top of the washer. The switches feel OK. Other than installing another board, is there another test? Is there a fuse on the board itself that I'm missing. My research indicates it should take a 22004257 control panel. The serial number of the unit is 34098865ET TIA
