| » error code e41 |
Hi.
The E41 code means that the control board sensing a bad door latch. Remove the door latch and check the resistance of the PTC (brown wax motor). Should be around 1500 ohm. Check connectors at the latch and control board, wire harness.If the resistance is way off - replace the door latch. Post the model number and I'll get you the part. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| ERROR CODE F6E5 Cancel key error | tammike | Oven Repair (including Ranges and Cooktops) | 8 | 08-06-2012 08:54 AM |
| Duet error code FH and diagnostic code C03 | angelo78 | Washer Repair | 0 | 03-21-2012 08:12 AM |
| Error code F31 | Zanesmom310 | Oven Repair (including Ranges and Cooktops) | 1 | 11-08-2011 04:34 PM |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
