Discuss
Stacked Washer/Dryer Washer won't drain
 in
Washer Repair
The washer drain pump valve isn't opening. The drain valve closed after I manually opened the pump and restarted the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Stacked Washer/Dryer Washer won't drain
  #1 (permalink)
Old 10-10-2012, 06:44 PM
Junior Member
Uncle Milt is on a distinguished road
Default Stacked Washer/Dryer Washer won't drain
Model Number: LT5005XMNO   Brand: Whirlpool   Age: More than 10 years
The washer drain pump valve isn't opening. The drain valve closed after I manually opened the pump and restarted the wash cycle. I had to manually move the spin cam bar when I reinstalled the drain pump. Could this be the Wig Wag Soleniod? Or could it be a defective door switch or timer?
Related Models
Whirlpool LT5005XMW0 LAUNDRY CENTER
Whirlpool LT5009XMW0 LAUNDRY CENTER
Whirlpool LT5100XSW0 Laundry Centers
Whirlpool LT5100XSW1 Laundry Centers
Whirlpool LT5100XVW0 LAUNDRY CENTER
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
Frigidaire LT600JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT600JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT600JXW1 Wwh(v5) / Tumble Action Washer
Whirlpool LT7000XTW0 LAUNDRY CENTER
Whirlpool LT7000XTW1 LAUNDRY CENTER
Whirlpool LT7000XVW0 Laundry Centers
Whirlpool LT7004XTW0 Laundry Centers
Whirlpool LT7004XTW1 Laundry Centers
Whirlpool LT7004XVW0 Laundry Centers
Frigidaire LT700EXD1 Wwh(v11) / Tumble Action Washer
Frigidaire LT700EXD4 Wwh(v12) / Tumble Action Washer
Frigidaire LT700EXD6 Wwh(v13) / Tumble Action Washer
Frigidaire LT700EXF1 Wwh(v14) / Tumble Action Washer
Frigidaire LT700EXF4 Wwh(v15) / Tumble Action Washer
Frigidaire LT700EXF6 Wwh(v16) / Tumble Action Washer
Frigidaire LT700EXH1 Wwh(v17) / Tumble Action Washer
Frigidaire LT700EXH4 Wwh(v18) / Tumble Action Washer
Frigidaire LT700EXH6 Wwh(v19) / Tumble Action Washer
Frigidaire LT700EXV1 Wwh(v20) / Tumble Action Washer
Frigidaire LT700EXV4 Wwh(v21) / Tumble Action Washer
Frigidaire LT700EXV6 Wwh(v22) / Tumble Action Washer
Frigidaire LT700EXW1 Wwh(v23) / Tumble Action Washer
Frigidaire LT700EXW4 Wwh(v24) / Tumble Action Washer
Frigidaire LT700EXW6 Wwh(v25) / Tumble Action Washer
Frigidaire LT700JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT700JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT700JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT700JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT700JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT700LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT700LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT700LXW1 Wwh(v1) / Tumble Action Washer
Whirlpool LT7100XVW0 Laundry Centers
Frigidaire LT800EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT800EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT800EXD6 Wwh(v3) / Tumble Action Washer
Frigidaire LT800EXF1 Wwh(v4) / Tumble Action Washer
Frigidaire LT800EXF4 Wwh(v5) / Tumble Action Washer
Frigidaire LT800EXF6 Wwh(v6) / Tumble Action Washer
Frigidaire LT800EXH1 Wwh(v7) / Tumble Action Washer
Frigidaire LT800EXH4 Wwh(v8) / Tumble Action Washer
Frigidaire LT800EXH6 Wwh(v9) / Tumble Action Washer
Frigidaire LT800EXV1 Wwh(v10) / Tumble Action Washer
Frigidaire LT800EXV4 Wwh(v11) / Tumble Action Washer
Frigidaire LT800EXV6 Wwh(v12) / Tumble Action Washer
Frigidaire LT800EXW1 Wwh(v13) / Tumble Action Washer
Frigidaire LT800EXW4 Wwh(v14) / Tumble Action Washer
Frigidaire LT800EXW6 Wwh(v15) / Tumble Action Washer
Frigidaire LT800JXD1 Wwh(v1) / Washer
Frigidaire LT800JXF1 Wwh(v2) / Washer
Frigidaire LT800JXH1 Wwh(v3) / Washer
Frigidaire LT800JXV1 Wwh(v4) / Washer
Frigidaire LT800JXW1 Wwh(v5) / Washer
Frigidaire LT800LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT800LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT800LXW1 Wwh(v1) / Tumble Action Washer
Amana LTA85AW WASHER- HORIZONTAL AXIS
Amana LTC85AW WASHER- HORIZONTAL AXIS
Whirlpool LTE5243BN0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ3 LAUNDRY CENTER
Whirlpool LTE5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT2 LAUNDRY SYSTEM
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
  #2 (permalink)
Old 10-18-2012, 08:58 AM
Junior Member
Red face
It was the pump pulley. Threads were stripped out on the pullley and the pulley was just spinning on the impeller shaft. It should be noted that the impeller shaft threads were ok. It turns out the wig wag solenoid was working properly. I just didn't see it run thru the cycles.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 2 10-15-2015 11:39 AM
Washer/Dryer Stacked Unit - Washer won't start! dru Washer Repair 4 09-21-2012 02:44 PM
Stacked washer dryer jjarps Washer Repair 1 01-30-2012 05:49 PM
Stacked washer and dryer AmberL Dryer Repair 0 01-19-2011 10:27 AM
stacked washer dryer housewife Washer Repair 0 06-05-2008 08:11 AM
