Bobbi: I have a Roper Whirlpool Washer model #RTW4440VQ1 Bobbi: I have a question about a problem Bobbi: I put a load of clothes in and in the very beginning wash stage a bed sheet became wrapped around the agitator Bobbi: it began to make a loud noise Bobbi: almost like when the tub gets off balance Bobbi: I stopped the machine removed the clothes and it continued to make the noise once turned back on Bobbi: I spun the water out and it did not make the noise, I filled it back up and tried again and the same noise continued Bobbi: I took the top off the agitator, took the base of the agitator out and turned it on, and no noise Bobbi: I put the bottom of the agitator back in and the noise resumed Bobbi: any ideas? Bobbi: the gear and pinion has been suggested, I am going to tear the machine apart to see if I can see anything damaged but thought I would ask before I started if there was anything in particular I should check first
Groups: APP Team
When I entered my last post I didn't know that my agitator is only twisting one way and causing the clothes to get twisted around the agitator. I originally thought a sheet being twisted around the agitator caused the problem but I now know that the agitator isn't agitating correctly, it is twisting in only one direction and causing everything to get jumbled up.
Groups: APP Team
Hi.
If the lower portion of the agitator turns only in one direction that's bad transmission.
Simon.
