| » Washer Will Bot Spin |
Model Number: SM8525148A Brand: Roper Age: 1 - 5 years
My washer will not spin but does drain, I have read other posts and am stuck. I have the washer dismanted. How can I determine if it is the clutch assembly or the clutch lining, nothing appears to be broken or snapped off. Looking for some direction before I purchase parts from your website
Thanks Derek Ads By Google Related Models |
Hi.
Please provide the correct model number, the one you posted doesn't come up. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Model is a RAS7133PQ0
Type 111 The actual clutch cylindar looks ok, no bent parts but the lining has (@) pads on them look a bit worn, the bushing looks a little worn but does snap into the clutch assenbly. Tight on money and I want to try to get the correct parts. Thanks Derek |
The couplers look good, no broken plastic pieces, rubber coupler looks in tacked.
What should I be looking for on a damaged/worm drive block, also do I need the special spanner to actually remove the nut on top of the drive block or will a small pipe wrench do the job? Thanks for your patience, I love to do all my own DIY repairs thanks Derek |
Hi.
If the two grooves on the top of the drive block still there and locked with the basket drive's "teeth" the block is good. You need the spanner ranch to remove the nut(if you need to). Simon.
__________________
| Display Modes | |
| Washer wont spin motor runs but ticking sound occurs when on spin cycle | D.Wick | Washer Repair | 1 | 01-07-2012 09:28 AM |
| LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack | mrdhoffman | Washer Repair | 1 | 08-30-2011 06:45 PM |
| Front load washer won't spin water out of clothes on last spin cycle | Tracey Finley | Washer Repair | 1 | 06-28-2011 05:10 PM |
| My washer drum spin when in spin cycle but the agitator agitates | cesarbazan | Washer Repair | 0 | 06-21-2011 06:13 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
