Direct Drive motor new and just "hums"
A seal gave out and leaked water inside all the working parts in my washer so I basically replaced everything.
When I got it back together the motor spun and was a little loud but then stopped and only hummed and dimmed the lights on the circuit I had it plugged into while testing. I then unhooked it from the transmission and tried and all it did was hum. Naturally I bought a new motor... same deal. Just a hum and it's getting hot. Any help? |
Thanks for the help :mad:
Quote:
You need to measure the capacitance using the multimeter.
It should be around 200 MF. Simon. |
Bought a new capacitor. Still hums. Will start spinning once I manually spin it. Will NOT start itself??? WHAT THE HECK!!! Brand new motor, brand new capacitor.
Bump for some help please. My family of 7 needs to do laundry
Hi.
Check the wire harness and all the disconnect plugs (at the motor switch, timer and between). Check for broken wire at the motor plug. Simon. |
The timer contacts for start current may be blown open, amprobe would confirm. If the cover will come off the timer, just check for burnt contacts.
1 Attachment(s)
This mean anything? This is next to the washer settings dial. Also the clear plastic tube that is attached to the same unit has a cut in it. HELP :(
| All times are GMT -7. The time now is 10:29 PM. |
