| » Direct Drive motor new and just "hums" |
Looks like you need to replace the water level switch, the spade terminal to it, and the plastic tubing to it. The hum was probably from the water solenoid and not the motor. A failure of the start current from the timer would have tripped the breaker in the house electrical panel.
__________________
Quote:
Can you tell me or point me to what the timer is. What seems like a timer in mine looks fine. Where can I put ohm meter to test these parts? Also the pressure switch is discontinued? So I am just out of luck?
Quote:
Eric |
Quote:
and what problems can the pressure switch incur??? |
With timer set to normal wash cycle when it should be agitating, check for continuity on the timer terminals (24 terminal block) between the Yellow and Blue wires, and between the Red and White/Black wires. The Red and Yellow wires are the feed to the motor start winding. With timer set to spin cycle, you should have continuity between the Yellow and White/Black wires and between the Red and Blue wires. That's the reverse of agitate. Reversing the feed to the start winding reverses the direction of rotation of the motor. Obviously, do these checks with the power off.
Eric |
Quote:
MOTOR, CAPACITOR, and TIMER! what else could this be?????? |
Faulty wiring or connections. The wires to the start winding are red and yellow. The red goes to two different terminals on the timer as does the yellow wire. Same goes for the blue wire and the white/black wire. This is the feed to the timer. You'll need to trace these wires to find out where their junction points are and check continuity on them as well as a good visual inspection. If you can spin the motor shaft while it's humming and it starts running normally, it's because it isn't getting power to the start winding. BTW, don't let that motor sit there and hum for long as it's drawing a lot more current that way.
Eric |
| Display Modes | |
| Neptune MD5500 Washer:Error Codes "do" and "FL" with a triple beep and a buzzer sound | neptune123 | Washer Repair | 1 | 06-12-2011 04:14 PM |
| Kitchen Aide Ice Maker cause "snow" where ice should come out.Ice "Cubes" are crushed | lauriejb | Refrigerator & Freezer Repair | 0 | 05-29-2010 08:58 AM |
| oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open | samej71 | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2010 07:05 AM |
| dryer only "hums" when power button is pushed, light on inside drum | mastersaint | Dryer Repair | 3 | 01-08-2009 11:25 AM |
| GE dryer "hums" but won't spin. | ocmike | Dryer Repair | 1 | 09-19-2008 09:19 AM |
