| » maytag stack LSG7806AAE |
Model Number: LSG7806AAE Brand: Maytag Age: 5 - 10 years
my maytag washer will not fill or turn on on any setting for the different wash cycles. when i turn the knob to the rinse cycle it spins but no water. Spoke with a helpful tech and he said the pressure switch is likely bad. Are these the symptoms of a bad pressure switch? Any other opinions from techs? The fuse looks fine.
Thanks Ads By Google Related Models |
That's a possibility, along with the control unit. and the water valve system.
Try replacing the pressure switch and see what happens. If you buy from this site you can return the part if it does not fix the problem.
__________________
| Display Modes | |
| maytag lsg7806aae shuts off on timed cycle but not custom dry cycle? | pullinin | Dryer Repair | 1 | 07-14-2011 04:34 PM |
| Maytag stack leaks | sigcon56 | Washer Repair | 0 | 12-05-2010 03:18 PM |
| maytag stack washer dryer | tdbates6 | Washer Repair | 1 | 12-02-2009 12:38 PM |
| Help with Maytag Stack.. | Melis | Washer Repair | 3 | 07-28-2009 05:21 AM |
| Maytag Stack Lid Switch Repair | rbooher2003 | Washer Repair | 1 | 01-11-2008 08:51 AM |
