washer displays the code Ld and lid is unlocked and full of water. can't get any responses from buttons. After unplugging for several minutes and then choosing the drain and spin option it will drain the water. Has had an Sd code also, I use the He detergent. during the period before the Ld when it should be draining and spinning you can hear a humming.
The trouble with these models is that it can be several problems, including a bad pump or bad control unit.
Look under the top panel and see if you can locate the tech notes that will tell you how to do some testing and diagnosing. I am guessing a problem with the drain pump.
