Discuss
Washer won't drain
 in
Washer Repair
No hose blockage, pump is driven direct by motor shaft, impeller is in tact. Is there a valve or some
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain
  #1 (permalink)
Old 10-04-2012, 11:33 AM
Junior Member
joemorin is on a distinguished road
Default Washer won't drain
Model Number: LCE462L W*1   Brand: Frigidaire   Age: 5 - 10 years
No hose blockage, pump is driven direct by motor shaft, impeller is in tact. Is there a valve or some other possible reason for water to not drain out?
Ads By Google
Related Models
Frigidaire LCE462LL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462LL2 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462LW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462LW2 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462PL0 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462PL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE462PW0 Frg(v1) / 24 " Laundry Center
Frigidaire LCE462PW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE702ADD1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE702ADD3 Frg(v1) / 27 " Laundry Center
Frigidaire LCE702AWD2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE702AWW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE702AWW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE702AWW3 Frg(v2) / 27 " Laundry Center
Frigidaire LCE732LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE732LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE732LL2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE732LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE732LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE732LW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE752LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LL2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE752LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE752LW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LL2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE852LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE852LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE852LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE852LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE902ADD1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE902AWW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCG701ADD1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG701ADD2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG701AWW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG701AWW2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG731LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG751LL2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG751LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LW2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LW3 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LL2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LL3 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LW2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LW3 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG851LL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG851LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG851LW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG851LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG901ADD1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG901AWW1 Frg(v1) / 27 " Gas Laundry Center
Amana LCI-522 Range - S/c S/i Ddraft Gas
Whirlpool LCK1100
Whirlpool LCK2001
Whirlpool LCK4500
Whirlpool LCK4600
Maytag LCLE700 Range - Std Mwave Ele
Maytag LCLE750 Range - Std Mwave Ele
Maytag LCLG600 Range - Std Mwave Gas
Maytag LCLG601 Range - Std Mwave Gas
Maytag LCME300 Mwave - Cntrtp / Stand Alone
Maytag LCME301 Mwave - Cntrtp / Stand Alone
Maytag LCME400 Mwave - Cntrtp / Stand Alone
Maytag LCME500 Mwave - Cntrtp / Stand Alone
Maytag LCME501 Mwave - Cntrtp / Stand Alone
Maytag LCME601 Mwave - Cntrtp / Stand Alone
Maytag LCME700 Mwave - Cntrtp / Stand Alone
Maytag LCME701 Mwave - Cntrtp / Stand Alone
Maytag LCME901 Mwave - Mounted Under Cabinet
Maytag LCNE200 Range - F/s Std Ele
Maytag LCNG200 Range - F/s Std Gas
Maytag LCNG201 Range - F/s Std Gas
Maytag LCNP200 Range - F/s Std Gas
Maytag LCNP201 Range - F/s Std Gas
Whirlpool LCR5232DQ0
Whirlpool LCR5232DQ1
Whirlpool LCR5232DQ2
Whirlpool LCR5232DQ3
Whirlpool LCR5232DQ4
Whirlpool LCR5232DQ5
Whirlpool LCR5232DZ0
Whirlpool LCR5232DZ1
Whirlpool LCR5232DZ2
Whirlpool LCR5232DZ3
Whirlpool LCR5232DZ4
Whirlpool LCR5232DZ5
Whirlpool LCR5232HQ0
Whirlpool LCR5232HQ1
Whirlpool LCR5232HQ2 Compact Automatic Washer
Whirlpool LCR5244AN0
Whirlpool LCR5244AN1
Whirlpool LCR5244AW0
Whirlpool LCR5244AW1
Whirlpool LCR7244DQ0
Whirlpool LCR7244DQ1
Whirlpool LCR7244DQ2
Whirlpool LCR7244DQ3
Whirlpool LCR7244DQ4
Whirlpool LCR7244DQ5
Whirlpool LCR7244DZ0
Whirlpool LCR7244DZ1
Whirlpool LCR7244DZ2
Whirlpool LCR7244DZ3
Whirlpool LCR7244DZ4
Whirlpool LCR7244DZ5
Whirlpool LCR7244HQ0
Whirlpool LCR7244HQ1
Whirlpool LCR7244HQ2 Compact Automatic Washer
  #2 (permalink)
Old 10-04-2012, 12:44 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
There is no miracles check all drain noses,the drain hole in the outer tub, if the drain hose not too far in the drain pipe.
Check if the impeller is not loose and motor reversing in spin.
Here are the breakdown diagrams and Replacement parts for Frigidaire LCE462LW1 Frg(v1) / 24 " Laundry Center | AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-04-2012, 01:26 PM
Junior Member
Default
Thanks--I'll check all.
Joe
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not drain Randy2b7 Washer Repair 0 02-29-2012 05:55 PM
Washer will only drain if put on "Drain+Spin" cycle. Arieleno Washer Repair 7 11-02-2011 07:03 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
Washer will not drain jscallstar Washer Repair 1 05-10-2010 04:53 AM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 01:41 PM
