Whirlpool washer will drain but wont spin
When my washer goes into the spin cycle it will drain and sounds like it is spinning but the tub holding the clothes is not spinning and I have soaked clothes. They are clean but still dripping wet. What may be the problem and can it be fixed.
Hi.
Check if the washer agitates. If it's not - most likely there is bad motor coupling Part number: 285753A Post the results. Simon. |
It agitates fine and it drains out and sounds like it it spinning but the tub inside doesn't spin to get all the water out.
Hi.
Remove the agitator and check the drive block Part number: 389140 If that is OK -replace the clutch Part number: 285785 Post the results. Simon. |
| All times are GMT -7. The time now is 01:03 AM. |
