Discuss
washer wont drain or spin after replacing balancing ring
 in
Washer Repair
After replacing the balancing ring on a whirlpool roper washer model # roper RAX7245JQO, the washer will fill and washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer wont drain or spin after replacing balancing ring
  #1 (permalink)
Old 10-03-2012, 01:59 AM
Junior Member
mn2az87 is on a distinguished road
Default washer wont drain or spin after replacing balancing ring
Model Number: roper RAX7245JQO   Brand: Roper   Age: 5 - 10 years
After replacing the balancing ring on a whirlpool roper washer model # roper RAX7245JQO, the washer will fill and washer but wont drain, spin, or rinse from that point on. From what I've read it sounds like the lid switch is not working properly..... I am not the one that replaced the balancing ring so not really sure of what happened so I wanted to get any opinions of things to look for before going over to friends house tomorrow to try and figure out what they did wrong.
As always thanx in advance for any and all help TJ
Ads By Google
Related Models
Frigidaire RP13M2WS2B Gib(v4) / Top Mount Refrigerator
Frigidaire RP13M2WS2C Gib(v5) / Top Mount Refrigerator
Frigidaire RP13M2WS2D Gib(v6) / Top Mount Refrigerator
Amana RR MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1 RANGE- S/C S/I DDRAFT GAS
Amana RR-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1000 RANGE- S/C S/I DDRAFT GAS
Amana RR-1000 MWAVE- CNTRTP / STAND ALONE
Amana RR-1010 RANGE- S/C S/I DDRAFT GAS
Amana RR-1010 MWAVE- CNTRTP / STAND ALONE
Amana RR-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-10A MWAVE- CNTRTP / STAND ALONE
Amana RR-1110 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1225 MWAVE- CNTRTP / STAND ALONE
Amana RR-3H RANGE- S/C S/I DDRAFT GAS
Amana RR-4 RANGE- S/C S/I DDRAFT GAS
Amana RR-4D RANGE- S/C S/I DDRAFT GAS
Amana RR-4DW RANGE- S/C S/I DDRAFT GAS
Amana RR-5B MWAVE- CNTRTP / STAND ALONE
Amana RR-7 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 MWAVE- CNTRTP / STAND ALONE
Amana RR-7A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE- CNTRTP / STAND ALONE
Amana RR-7D RANGE- S/C S/I DDRAFT GAS
Amana RR-7DA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-800 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-820 MWAVE- CNTRTP / STAND ALONE
Amana RR-8A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8T MWAVE- CNTRTP / STAND ALONE
Amana RR-8TC MWAVE- CNTRTP / STAND ALONE
Amana RR-9 RANGE- S/C S/I DDRAFT GAS
Amana RR-900 MWAVE- CNTRTP / STAND ALONE
Amana RR-910 RANGE- S/C S/I DDRAFT GAS
Amana RR-910 MWAVE- CNTRTP / STAND ALONE
Amana RR-9T MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE- CNTRTP / STAND ALONE
Amana RR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TB MWAVE- CNTRTP / STAND ALONE
Amana RR-II RANGE- S/C S/I DDRAFT GAS
Amana RR1020 MWAVE- CNTRTP / STAND ALONE
Amana RR1220 MWAVE- CNTRTP / STAND ALONE
Amana RR2 MWAVE- CNTRTP / STAND ALONE
Amana RR510 MWAVE- CNTRTP / STAND ALONE
Amana RR510A MWAVE- CNTRTP / STAND ALONE
Amana RR52 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54D MWAVE- CNTRTP / STAND ALONE
Amana RR56 MWAVE- CNTRTP / STAND ALONE
Amana RR57D MWAVE- CNTRTP / STAND ALONE
Amana RR59T MWAVE- CNTRTP / STAND ALONE
Amana RR6W MWAVE- CNTRTP / STAND ALONE
Amana RR7 MWAVE- CNTRTP / STAND ALONE
Amana RR720 MWAVE- CNTRTP / STAND ALONE
Amana RR9 MWAVE- CNTRTP / STAND ALONE
Amana RR920 MWAVE- CNTRTP / STAND ALONE
Amana RRC57D MWAVE- CNTRTP / STAND ALONE
Amana RRH-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE- CNTRTP / STAND ALONE
Amana RRL-10C MWAVE- CNTRTP / STAND ALONE
Amana RRL-10TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-10XA MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE- CNTRTP / STAND ALONE
Amana RRL-7C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-7C MWAVE- CNTRTP / STAND ALONE
Amana RRL-8T MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TC MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TD MWAVE - FAMILY SIZE (60 HZ)
  #2 (permalink)
Old 10-03-2012, 09:30 PM
Senior Member
allen9258 is on a distinguished road
Default
raise the panel and see he plug the connection back up the one that the lid switch is attached to also check the lid switch
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer wont drain or spin Alluongo Washer Repair 3 05-05-2011 07:04 AM
Washer wont drain or spin Rodney316 Washer Repair 1 09-08-2010 05:15 PM
Balancing Ring problem Eldon Kelly Washer Repair 0 08-24-2010 11:50 AM
washer wont spin or drain rday Washer Repair 1 11-03-2009 04:28 PM
Replacing Ring Deadening sound ring part # 63134 JOANBAPP Washer Repair 2 10-31-2009 06:56 PM
