| » Whirlpool frontload washer F-20 |
Model Number: wfw8300sw04 Brand: Whirlpool Age: 1 - 5 years
I have replaced the water valve unit that the hoses attach to and I have replace the pressure switch.
Once I replaced those I unplugged the unit for about 30 seconds and tested the machine and after it fills with water it still stops and flashes the f-20 code. So I am at a loss at what to do next short of purchasing a new washer. This unit is maybe 5 years old. Thank you for any help you guys can provide. Ads By Google Related Models |
Hi.
Check the pressure switch hose. Press cancel twice, washer should drain for 3 min. If the drain pump is OK check the connections at the control board and wire harness. If everything checks OK - replace the CCU Part number: W10246289 Remember that you can return any unused parts to APP even installed ones. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Frontload Washer | elayne.perry@verizon.net | Washer Repair | 1 | 06-15-2011 10:50 AM |
| Whirlpool 24" Frontload Spin problem | jlamson | Washer Repair | 1 | 06-29-2010 02:37 PM |
| GE Frontload washer leaking | sngltrck | Washer Repair | 0 | 12-29-2009 10:33 AM |
| Help my frontload washer won't spin | kramerica | Washer Repair | 0 | 11-29-2009 06:48 PM |
| Frontload Washer | angeleyesz | Washer Repair | 1 | 09-11-2009 04:28 PM |
