Discuss
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
 in
Washer Repair
We have a front-loading Whirlpool washer that sits in our closet with a dryer stacked on top. Initially, our washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
  #1 (permalink)
Old 10-01-2012, 04:51 PM
Junior Member
adava is on a distinguished road
Default Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
Model Number: WFC7500VW0   Brand: Whirlpool   Age: 1 - 5 years
We have a front-loading Whirlpool washer that sits in our closet with a dryer stacked on top. Initially, our washer wasn't going into spin mode, so when the cycle completed, our clothes would be dripping wet. We ran the diagnostics test as well, and it didn't come up with any error codes, and the spin cycle worked in the diagnostic mode. We read on a lot of websites that when this happens it may be a door lock switch problem that causes it to skip the spin cycle. We also read that an imbalance can cause this, and our stackable set is on wood floors.
We pulled out the washer from the closet and attempted to check the hoses and empty them. We put everything back in, and ran the washer. This time, the spin cycle did start...?! Not sure why. But, it seems like the washer is still having some problems with draining, as it seems to sit in that cycle for an extended period of time - meaning that the clock on the front of the washer says it will be done in 45 minutes, but it ends up taking about a total of 65 minutes. It seems like it spends a lot of time draining, and a very short time in spin.
Then, today, the washer stopped spinning again (still works in diagnostic mode).
We did clean the pump filter. The only thing in it was a penny. We are using HE detergent, and a very little amount per wash. We've checked the filter, drain hose, stand pipe, and ECO valve (under the drum) and found no blockages. There were no blockages in the drain motor that we could see (however I did not disassemble the rectangular part in the rear behind the drain hose).
When running an empty load on a Rinse/Drain cycle, the water in the barrel drains very quickly, within 20 seconds, but the washer then continues to try to pump out water for the next 8 minutes (even though there is no visible water in the drum) as the drum agitates in alternating directions as if it is trying to "re-balance" the empty load. The pump is powerful enough to cause the empty drain hose to jerk about behind the washer. Eventually
it gives up and moves on; skipping the high-speed spin.
Any ideas? Thanks in advance!
Ads By Google
Related Models
Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER
Whirlpool WFC7500VW1 WASHER
Whirlpool WFE114LWS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE115LXB0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE115LXQ0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE260LXS0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE301LVB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE321LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWQ1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWS1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE361LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVD1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVT1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE364LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE366LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE374LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
White Westinghouse WFF334GCA ELECTRIC RANGE
White Westinghouse WFF334GCB ELECTRIC RANGE
Whirlpool WFG110AVQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG111SVQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG114SVB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG114SVQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG114SVT0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG114SVW0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool WFG114SWB0 30" GAS FREESTANDING RANGE
Whirlpool WFG114SWQ0 30" GAS FREESTANDING RANGE
Whirlpool WFG114SWT0 30" GAS FREESTANDING RANGE
Whirlpool WFG231LVB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Whirlpool WFG231LVQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Whirlpool WFG231LVS0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC I
Whirlpool WFG361LVB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVB3 30" GAS FREESTANDING RANGE
Whirlpool WFG361LVD0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVD1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVD2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVD3 30" GAS FREESTANDING RANGE
Whirlpool WFG361LVQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVQ3 30" GAS FREESTANDING RANGE
Whirlpool WFG361LVS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVS3 30" GAS FREESTANDING RANGE
Whirlpool WFG361LVT0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVT1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVT2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG361LVT3 30" GAS FREESTANDING RANGE
Whirlpool WFG366LVB0 30" GAS FREESTANDING RANGE
Whirlpool WFG366LVQ0 30" GAS FREESTANDING RANGE
Whirlpool WFG366LVS0 30" GAS FREESTANDING RANGE
Whirlpool WFG366LVT0 30" GAS FREESTANDING RANGE
Whirlpool WFG371LVB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVB3 30" GAS FREESTANDING RANGE
Whirlpool WFG371LVD0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVD1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVQ2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVQ3 30" GAS FREESTANDING RANGE
Whirlpool WFG371LVS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG371LVS3 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVB2 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVB3 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVD0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVD1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVQ2 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVQ3 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG374LVS2 30" GAS FREESTANDING RANGE
Whirlpool WFG374LVS3 30" GAS FREESTANDING RANGE
Whirlpool WFG381LVB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG381LVB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Whirlpool WFG381LVB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
  #2 (permalink)
Old 10-02-2012, 04:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the top panel and locate the pressure switch (#5 at the diagram). Dosconnect the hose from the pressure switch and blow some air trhough the hose to make sure it is clean.
Reconnect the hose and give it a try. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front loader will not start and cannot enter Diagnostic Mode easyrdr Washer Repair 0 05-05-2012 09:19 AM
Whirlpool Front Loading Washer (code F-11) GDOMB Washer Repair 1 10-22-2010 11:39 AM
Whirlpool Duet Front Loading Washer GDOMB Washer Repair 3 10-22-2010 11:32 AM
Whirlpool front loading washer spinning problems godp1301 Washer Repair 2 02-23-2010 06:24 AM
whirlpool duet gas dryer no heat except in diagnostic mode washerman101 Dryer Repair 0 08-10-2009 02:36 PM
