| » Hub nut won't loosen!!! |
Model Number: wbsr3140g1ww Brand: GE Age: 1 - 5 years
Ok so the mode shifter on my washer crapped out so I ordered a new shifter, belt and hub nut wrench from here. Everything came apart easily until I got to the hub nut. This sucker won't budge! I know it's reverse thread and I read you gotta whack the wrench with a deadblow hammer..... I did this and the sucker still won't budge! It's hard to get any momentum on the hammer because you have limited swing area in the basket. I'm thinking my next option is to heat up the nut with a torch. Any advice on this or any other ideas would be appreciated. This thing is kicking my butt.
Per the GE instructions attached to the post, if spanner wrench did not work, you have to use much more powerful impact wrench.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You could try Liquid Wrench Penetrating Oil.
Put it on and then check it every half hour or so in case it needs more. Then let it sit overnight so it can soak in. Just be sure to clean it up before reassembly
__________________
| Display Modes | |
| How to loosen/tighten tube clamp? | pta | Refrigerator & Freezer Repair | 0 | 10-01-2011 09:38 AM |
| Screw holding wash impellar won't loosen | rbayer | Dishwasher Repair | 3 | 04-18-2008 03:46 AM |
