| » ge washer |
Model Number: wbvh6240fww Brand: GE Age: 5 - 10 years
I have gotten into test mode, display shows t01.
How do I run the test? I pressed and held the start button and it beeped and displayed a 3 that is the correct code for this model number. I have been unable to take the next step. Ads By Google Related Models |
Try to turn the select knob.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0WW Washer | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
What did it show for t2?
What was the original problem? Gene.
__________________
[quote=Gene;773067]Try to turn the select knob.
Washer tumbles before filling with water. Afterwards, it doesn't tumble or spin. t1 returns 00 t2 returns 00 T10, drains washer but doesn't tumble. T11, doesn't spin at all and returns 0 for both tests. |
Each time the washer starts, a wake up routine should be initiated:
The door locks. The wash basket briefly tumbles in both directions. The door unlocks. The door locks. The fill cycle begins. Did it do it? If you did hear the click from the door lock, verify if the door was really locked. Gene.
__________________
Quote:
Check the inverter and the motor as described in the attached files. Post the results.
__________________
Thanks for all your help. The plastic box only contains connectors so I am assuming that this is not the inverter. I assume the inverter is the metal box to the rear of the plastic box. It has two heat sinks on it. That box is humming when the drum should be turning.
| Display Modes | |
