| » Kenmore Washer Help |
Model Number: 110.16512690 Brand: Kenmore Age: 1 - 5 years
I have a Kenmore washer and the other night during a load oflaundry the washer started making a loud noise during the spin cycle. When I started the next load the noise wasthere from the beginning so I checked inside to find that the agitator and thetub both were not moving at all. They won’tmove at all during the entire wash cycle. Checked the motor and it works fine. I replaced the Direct Drive Motor Coupling hoping that might be the problem. No such luck. I’m thinking that it might be the transmission since the main output shaftdoes not spin when the motor is running. I just want to make sure before I replace it that it’s not somethingelse like the clutch, brake or the drive block. Ads By Google Related Models |
Hi.
Remove the agitator and check if the transmission shaft moves during wash cycle and if the drive block is OK. If the shaft not moving and block is fine - replace the transmission Part number: 3360629 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| KEnmore Washer won't run | theprofessordan | Washer Repair | 0 | 05-27-2012 05:47 PM |
| kenmore washer-installing clips for the top of the washer | donnadean | Washer Repair | 1 | 02-17-2010 11:49 AM |
| Kenmore/ WCI washer | swspencer | Washer Repair | 1 | 02-13-2010 03:26 PM |
| kenmore washer | mrclean6507 | Washer Repair | 1 | 11-18-2009 02:30 PM |
| Kenmore elite washer is leaking under washer | cbs | Washer Repair | 1 | 07-12-2009 06:27 PM |
