| » Magtag washer not spinning, smoking belts |
Model Number: lsg7806aae Brand: Maytag Age: More than 10 years
My maytag washer (2 belt-pulley system) won't spin and the main belt that connects to the center flywheel on the bottom is not turning and smoking. From what I see, that main flywheel won't turn more than 1/2 turn before it gets jammed, stopping the belts from turning and no amount of physical pressure and turn it (clockwise), however it does turn freely all day in the counterclockwise/wrong direction by hand.
The belts starts smoking under the motor @ the double pulley. From what I've seen online it's suggested that I replace a metal liner sleave (part #211130) and the mounting stem rpr. kit (part #6-2095720) with spanner (#22038313). Does this sound right? Do you use any special lubricant to lube any of these parts? thanks Ads By Google Related Models |
Hi.
Most likely the tub bearing kit should be replaced Part number: 6-2040130 Along with it replace the mounting stem kit Part number: 6-2095720 You will need the spanner ranch Part number: 22038313 Don't forget to replace the belts. Here are the breakdown diagram and Replacement parts for Maytag LSG7806AAE STACKED LAUNDRY- GAS | AppliancePartsPros.com Good luck. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Is there any potential brake system issue with this since the bottom flywheel which controls the agitator won't continue to turn more than 1/2 rev. clockwise until it stops dead. Is there any way to test if this is a/the problem.
thanks. |
Hi.
Most likely it's the bearings and the way to check it is to take it a part. Simon.
__________________
| Display Modes | |
| Magtag Washer Motor | Terry505x | Dryer Repair | 1 | 08-15-2011 09:02 AM |
| Magtag not spinning | P51302 | Washer Repair | 4 | 06-04-2011 04:49 AM |
| Smoking belts on spin cycle | Kevco | Washer Repair | 2 | 10-11-2010 06:53 AM |
| magtag Washer | vlee | Washer Repair | 1 | 07-22-2010 11:28 AM |
| Frigidaire Washer Smoking, not Spinning | cesar960 | Washer Repair | 1 | 10-17-2008 12:19 AM |
