| » Water continues to fill washer during entire cycle |
Model Number: GLET1031FS4 Brand: Frigidaire Age: 1 - 5 years
Water will not shut off completely to my washer. It continued to slowly fill with water during all parts of cycle and when the washer is on off setting. The only way I could stop the water from entering washer was to shut it off at the water inlet from the house. Help!
Hi.
There is a bypassing water inlet valve which you need to replace Part number: 134890600 Here are the breakdown diagrams and Replacement parts for Frigidaire GLET1031FS4 LAUNDRY CENTER | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Hi.
Pull the unit off the wall.Disconnect the power,turn the water off, remove the hoses. Remove 2 screws at the bottom of the front panel, one on each side, and pull it down. Disconnect the wires from the lid lock and remove 2 screws one on each front corner. Lift and pull out the top. Take one screw holding the valve out from the back. Good luck. Simon.
__________________
Quote:
Thanks, Keegan |
Hi.
If the plugs are installed incorrectly the hot and cold water will be switched around. Select cold water only wash and check. Simon.
__________________
Quote:
Thanks so much, you've been super helful! The part arrived quickly and was fairly easy to replace thanks to your help. We have a well an have always had a problem with sediment clogging the filter on this part. Several months ago, we took the filter out of the water inlet valve because it is so difficult to clean. I'm sure that is what caused the filling problem, so we have put a filter into the hose at the wall which is a bit easier to clean. Thanks again! Keegan |
You are welcome.
Simon.
__________________
| Display Modes | |
| washer will not fill with water on any cycle but still runs on spin cycle help | Paul Linville | Washer Repair | 1 | 08-03-2012 11:39 AM |
| Washer continues to fill up | reneeallman | Washer Repair | 1 | 09-14-2011 07:27 PM |
| Refrigerator continues to fill water tray | dlandy | Refrigerator & Freezer Repair | 0 | 08-16-2010 09:07 AM |
| Water Continues To Fill | robinlayton | Washer Repair | 2 | 10-17-2009 01:15 PM |
| wASHER CONTINUES TO FILL THROUGHOUT CYCLE | armyguber | Washer Repair | 1 | 08-06-2009 03:26 PM |
