loud high pitch soud only on spin cycle.
hello all,
I'm reposting this cause i didn't give anough info on my maytag washer.it is model LAT8506AAE and its about fourteen years old(i know is old)but is built like tank and didn't have any problems till three years ago i changed the three dampening pads and it's still there no problem.the new problem is a very high pitch soud that comes on spin cycle only. If any one has any info on this problem,could you please respond.any info is appericiated.thanks. |
Hi Walter,
Remove the front panel. Run the washer and try to pinpoint that noise. Post the results. Here are the breakdown diagrams and Replacement parts for Maytag LAT8506AAE WASHER-TOP LOADING | AppliancePartsPros.com Gene. |
noisy spin cycle.
Hello gene,
thank you for your reply.i had taken the front panel afew times already but can't exactley tell where the noise is coming from but i am suspecting mostely from buttom,so could it be the clutch bearing or radial bearing? I also needed to know where can i get the spanner wrench in case if i have to remove the tub off to get to tub bearing. any info is appericiated.thanks |
Sounds like the problem is a bad tub bearing. The seal should be replaced too. It comes with the instructions.
- The spanner wrench Part number: AP4503397 - The tub bearing kit Part number: 6-2040130 - The washer stem and seal kit Part number: 6-2095720 Gene. P.S. There is a small chance that there something else caused that noise - http://forum.appliancepartspros.com/...pin-cycle.html |
| All times are GMT -7. The time now is 06:10 PM. |
