| » Frigidaire front loader flashes nine times |
Model Number: LTF2140FS2 Brand: Frigidaire Age: 1 - 5 years
Washer will not run. Vertical led's flash nine times,then repeats. Start button led never flashes. Never saw this before, washer just two years old. Washer can't be put in diagnostic mode. Hope someone has seen this before.
Ads By Google Related Models
__________________
Rich
My experience when I cannot get these models into diagnostic mode is to replace the control unit, not a guaranteed fix as the darn door lock assembly sometimes interferes with the control unit. In case you don't have it here is a link to the repair manual. http://www.emaservicetips.com/pdfs/4...isWasherSM.pdf
__________________
I agree Sidfink43. I think the error code is E95 which is a communication error and the fix is replace the control board.
The fact that the start led fails to light up and display 5 flashes means the circuit is probably blown out. I think the control initially sends power to the mcu and if the mcu has a failure, that msg is sent to the control where it promptly shuts the power off.This is a saftey issue. This I can check by monitoring the mcu power at startup. I will order a new control on this site as the old one just might be good, and the failure may be in the mcu.
__________________
An advanced Google search gave me a lot of info on this problem
Electronics are needed on these machines to prevent motor burnout and for safety. There is less than a 1/3 hp motor in these to get low power usage. There are electronic protections to prevent 1/2 or higher hp loads from damaging components.
__________________
| Display Modes | |
| control panel flashes 000 three times | nnicholas | Refrigerator & Freezer Repair | 0 | 01-16-2011 08:24 PM |
| frigidaire front loader | caleno | Washer Repair | 3 | 11-14-2010 05:32 PM |
| Frigidaire front loader | seminole | Washer Repair | 2 | 07-19-2010 06:20 AM |
| Frigidaire Front Loader won't run | hguyette | Washer Repair | 3 | 06-29-2009 11:15 AM |
| oven flashes lite 3 times | mwwhite50501@yahoo.com | Oven Repair (including Ranges and Cooktops) | 5 | 09-11-2008 12:45 PM |
