keep getting "water tap closed error"..have inspected in let and out let screens and they are clean..no kinked hoses..washer will eventualy complete a washing cycle, but must keep hitting start button 7 or 8 times. water pressure in adjacent faucets is normal. seems to drain fully. Repairman came out, said it must be the pump, Boschusa. said they doubted it was a pump issue..any ideas?
Can you tell us exactly what error code you are getting, and do you have a tech sheet which allows you to put the machine in trouble shooting mode?
do not have a tech sheet or details on how to pull codes
About the only thing I can recommend at this point is having a Bosch factory authorized tech look at it.
Sorry not to be more helpful. You may want to try another appliance Forum.
I am waiting for the tech, will post what the problem was if it helps others in the future...thanks for your time and effort..best regards
Thanks, we are always interested in info on these machines.
