Discuss
Clanking - Screeching - Won't spin
 in
Washer Repair
My washer makes a terrible clanking/screeching noise on agitation, and then it can't get started spinning. If I do only
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Clanking - Screeching - Won't spin
  #1 (permalink)
Old 09-24-2012, 12:37 PM
Junior Member
TruCelt is on a distinguished road
Default Clanking - Screeching - Won't spin
Model Number: WVSR1060G2WW   Brand: GE   Age: 5 - 10 years
My washer makes a terrible clanking/screeching noise on agitation, and then it can't get started spinning. If I do only very small loads, it will usually spin, but unreliably. (No noise when it does spin.)
If it's a normal sized load, and I bypass the lid switch, then fairly often I can start it spinning by hand and then it will complete the cycle. But sometimes - in no discernible pattern - it will simply lock up and the only way to get it to release is to go through the whole noisy nightmare again.
I bought this washer used about a year ago, so not sure how old it is. I bought a tub washer and a belt but haven't instaleld them yet - think that will fix it? Or is it something big like the trans?
Thanks for any advice you may have!
Ads By Google
Related Models
General Electric WVSR1060G2WW Washer
General Electric WVXR1040T2WW Washer
General Electric WVXR1040T3WW Washer
General Electric WVXR1040T4WW Washer
General Electric WVXR1040T5WW Washer
General Electric WVXR1040T8WW Washer
General Electric WVXR1040TAWW Washer
Jenn-Air WW2460B Walloven - S/c Ele
Jenn-Air WW2460W Walloven - S/c Ele
Jenn-Air WW27110B Walloven - S/c Ele
Jenn-Air WW27110W Walloven - S/c Ele
Jenn-Air WW27210B Walloven - S/c Ele
Jenn-Air WW27210P Walloven - S/c Ele
Jenn-Air WW27210PF Walloven - S/c Ele
Jenn-Air WW27210PG Walloven - S/c Ele
Jenn-Air WW27210PK Walloven - S/c Ele
Jenn-Air WW27210PR Walloven - S/c Ele
Jenn-Air WW27210PU Walloven - S/c Ele
Jenn-Air WW27210W Walloven - S/c Ele
Jenn-Air WW27430B Walloven - S/c Ele
Jenn-Air WW27430BC Walloven - S/c Ele
Jenn-Air WW27430P Walloven - S/c Ele
Jenn-Air WW27430PF Walloven - S/c Ele
Jenn-Air WW27430PG Walloven - S/c Ele
Jenn-Air WW27430PK Walloven - S/c Ele
Jenn-Air WW27430PR Walloven - S/c Ele
Jenn-Air WW27430PU Walloven - S/c Ele
Jenn-Air WW27430W Walloven - S/c Ele
Jenn-Air WW27430WC Walloven - S/c Ele
Jenn-Air WW2750B Walloven - S/c Ele
Jenn-Air WW2750W Walloven - S/c Ele
Jenn-Air WW2780B Walloven - S/c Ele
Jenn-Air WW2780B-C Walloven - S/c Ele
Jenn-Air WW2780W Walloven - S/c Ele
Jenn-Air WW2780W-C Walloven - S/c Ele
Whirlpool WW29000SU0 Laundry Worksurface
Whirlpool WW29000SW0 Laundry Worksurface
Jenn-Air WW30110B Walloven - S/c Ele
Jenn-Air WW30110W Walloven - S/c Ele
Jenn-Air WW30430B Walloven - S/c Ele
Jenn-Air WW30430P Walloven - S/c Ele
Jenn-Air WW30430PC Walloven - S/c Ele
Jenn-Air WW30430PF Walloven - S/c Ele
Jenn-Air WW30430PG Walloven - S/c Ele
Jenn-Air WW30430PK Walloven - S/c Ele
Jenn-Air WW30430PR Walloven - S/c Ele
Jenn-Air WW30430PU Walloven - S/c Ele
Jenn-Air WW30430W Walloven - S/c Ele
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
Maytag WW600 Mwave - Cntrtp / Stand Alone
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
  #2 (permalink)
Old 09-26-2012, 05:54 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Operate it with the front panel off and see if you can determine what is happening.
The first thing you should do is check for something caught between the tub and basket, that could cause your problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help, LOUD Clanking in spin cycle only arodgers Washer Repair 4 01-02-2012 04:33 PM
Washer spin cycle causes screeching s0ad Washer Repair 0 07-29-2011 12:46 PM
waser makes loud screeching while spin cycle john49 Washer Repair 2 07-15-2011 07:23 PM
Whirlpool washer wont spin/Loud clanking sound mparson1969 Washer Repair 7 01-20-2011 01:04 PM
Screeching Spin Cycle dzak Washer Repair 4 02-25-2008 11:21 AM
