Discuss
Reassembled front load now water smells moldy
 in
Washer Repair
A couple months after replacing rear bearing and seals we now have the moldy smell problem that these machines are
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Reassembled front load now water smells moldy
  #1 (permalink)
Old 09-23-2012, 04:48 PM
Junior Member
christo83 is on a distinguished road
Default Reassembled front load now water smells moldy
Model Number: 417.39012891   Brand: Kenmore   Age: 5 - 10 years
A couple months after replacing rear bearing and seals we now have the moldy smell problem that these machines are pron to but never had before. I didn't replace the gasket between the barrel half's but there no leaks there. The rubber boot looked good and is glued back into place on the door face. The only thing I can see that maybe causing an issue is there's still water in the pump boot and the water exit line at the end of the spin out. Maybe a pump issue?
Ads By Google
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
Last edited by christo83 : 09-23-2012 at 04:55 PM. Reason: wasn't able to post before, first line was just a test
  #2 (permalink)
Old 09-24-2012, 06:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It can be. Check the drain pump and the hoses.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-24-2012, 07:16 PM
Junior Member
Default
Thanks, I'm guessing there should be little if no water left in the boot off the pump and the exit water line. I have water in both.
  #4 (permalink)
Old 09-25-2012, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It does not drain out completely because water works as a lubricant for the pump impeller.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer smells moldy whenever idle J Black Washer Repair 60 06-06-2013 08:15 AM
replace moldy gasket on LG front loading washing machine jack shannon Washer Repair 0 11-05-2011 06:40 AM
washer smells / is moldy, "balance asm" full of water beek9029 Washer Repair 0 07-15-2010 06:00 PM
Front load washer fills with water when off volunteer2 Washer Repair 1 03-05-2010 03:44 PM
washer smells moldy all the time calfpen Washer Repair 5 02-11-2009 04:37 PM
