Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Reassembled front load now water smells moldy (http://forum.appliancepartspros.com/washer-repair/501049-reassembled-front-load-now-water-smells-moldy.html)
christo83 09-23-2012 04:48 PM
A couple months after replacing rear bearing and seals we now have the moldy smell problem that these machines are pron to but never had before. I didn't replace the gasket between the barrel half's but there no leaks there. The rubber boot looked good and is glued back into place on the door face. The only thing I can see that maybe causing an issue is there's still water in the pump boot and the water exit line at the end of the spin out. Maybe a pump issue?
Gene 09-24-2012 06:23 PM
It can be. Check the drain pump and the hoses.
christo83 09-24-2012 07:16 PM
Thanks, I'm guessing there should be little if no water left in the boot off the pump and the exit water line. I have water in both.
Gene 09-25-2012 01:42 PM
It does not drain out completely because water works as a lubricant for the pump impeller.
