Washer Leaking LCR7244DQ5
Brand: Whirlpool Age: 5 - 10 years
I have a Whirlpool compact washer (model: lcr7244dq5). My issue is that my washer is leaking water. I have replaced the pump twice. Thought it was the pump leaking the second time. Water leaks from the back center and the front and just water all underneath it. Not sure where it is comming from. I thought it may be the seal but not sure started taking the bottom apart to check and see if it was the seal. Found some water on the Cam, Splutch but still cannot find where it is leaking. Could could i get some help with this. Thanks!!
Ads By Google
