hello i have this washer it has worked fine. the wife used it and her swim suit was stuck under the agitator she got it out . i went to use it the other day and now the key pads dont work i checked power going to the machine it was fine and then i checked pins 2 and 4 on p16 connecter going to the machine control board it had 141 volts . i also pulled all the connectors and looked at them they wasnt corroded . what could be wrong ? and any help to diagnose would greatly appreciated. we r on a low budget right now. thank you
Originally Posted by: gksportster ...i checked pins 2 and 4 on p16 connecter going to the machine control board it had 141 volts... This voltage is too high and very likely damaged the control board. Call your electric company to solve this problem. You may want to use a good surge protector to prevent such problems. - The machine control board Part number: 8571359
