| » Whirpool washer not spinning, desperately need your help please |
Model Number: LSN2000LW1 Brand: Whirlpool Age: 5 - 10 years
Hi: A few months ago, my washer started having a problem with the spin cycle. It would go through the wash cycle and rinse cycle but sometimes at the end of the wash, the clothes are still wet. If the basket was turned manually, something catches and the spin cycle would then work. At other times, the spin cycle would work by itself. A week ago, it developed a second problem, it was filling up with water and draining. However, it was not agitating and the basket was not moving at all. The motor was running but there was a loud noise. The bottom of the washer was checked for grease stains but none were found. The motor coupling has since been replaced and the washer is now going through the wash cycle but is still not spinning. I desperately need your help. Thanks so much for your immediate reply. Ads By Google Related Models |
The likely problem is with the clutch. Read the Sticky at the top of the main washer page by Richappy on direct drive brakes, then replace this part
Part number: AP3094537 and check the brakes to make sure they are releasing during spin. The video on the part page will take you through the process.
__________________
Quote:
Thanks for your advice. Why can't it be the drive block? Please advise. |
| Display Modes | |
| Desperately need Whirlpool 1cwed5300vw0 Schematic | takoateli | Dryer Repair | 2 | 07-08-2012 06:12 AM |
| touchpad out completely need help desperately | rloubame | Oven Repair (including Ranges and Cooktops) | 3 | 12-13-2010 07:28 AM |
| Desperately in need of parts!!!!!! | smitty1968 | Oven Repair (including Ranges and Cooktops) | 1 | 04-15-2009 02:12 PM |
| Help...A Gaffers & Sattler Oven Safety Valve is desperately needed. | AdrienneInNY | Oven Repair (including Ranges and Cooktops) | 4 | 11-14-2008 06:23 AM |
| whirpool washer | Bennie | Washer Repair | 1 | 02-23-2008 09:10 AM |
