| » Removing control panel |
Model Number: 110.20602990 Brand: Kenmore Age: More than 10 years
I can't seem to figure out how to open or remove the control panel. Any help would be appreciated.
On this model you can pry off the end caps. This will expose screws on each side of the front of the console at the bottom of it. Take them out and the console will flip up.
Yep, that should do it.
__________________
Pull from the top, if you want to use a screw driver you can just be careful.
If you break one don't worry, they are easily replaceable, or can even be left off without affecting the operations of the machine.
__________________
Thanks much. I'll give it a try.
| Display Modes | |
| Need help removing control panel and front panel to get at the drain pump | jthenne | Washer Repair | 2 | 02-16-2011 02:15 PM |
| Removing control panel | cbelt | Washer Repair | 1 | 01-06-2011 07:05 PM |
| Removing control panel | mamacitizen | Oven Repair (including Ranges and Cooktops) | 1 | 03-08-2010 04:42 AM |
| Removing control panel | One More Try | Refrigerator & Freezer Repair | 0 | 02-02-2010 02:37 PM |
| Removing the control panel - how to do it???? | sean_lui | Microwave Repair | 1 | 07-28-2008 10:19 AM |
