hi, I called and they said I could go here for help I have ge front loader it works fine in the regular wash modes but when it gets to final spin cycle it doesn't do anything. It drains fine i cleaned out the drain on it had pennys and such in there but drains fine just doesn't spin at the end. I have tech book but don't know how to get to codes when i do what it says it just comes up 1 h.The door says it is locked can it say that and still not be? need help!!!! Thanks:)
GE will not release their tech data to non GE types, so I cannot link you to a repair manual. Normally what we would say in a situation like yours is that the main control unit has failed.
Try replacing it. If you buy from this site and the part does not fix the problem you can return it.
