Discuss
Kenmore Elite Washer only briefly pumps
 in
Washer Repair
My Kenmore Elite washer recently stopped pumping out all o the water. It begins pumping for about 2 seconds then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite Washer only briefly pumps
  #1 (permalink)
Old 09-12-2012, 07:45 AM
Junior Member
Starke24x is on a distinguished road
Default Kenmore Elite Washer only briefly pumps
Brand: Kenmore   Age: 5 - 10 years
My Kenmore Elite washer recently stopped pumping out all o the water. It begins pumping for about 2 seconds then stops. It also doesn't go into the spin cycle. I can have it remove the water by resetting it to the spin cycle where it will drain again for 2 seconds. I opened up the pump last night and didn't find any obstructions. What could make this happen? Could there be another obstruction somewhere else (maybe between inside the drum before the water enters the pump)? Thanks in advance for the help.
Ads By Google
  #2 (permalink)
Old 09-12-2012, 02:39 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please provide the model number of the washer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-12-2012, 04:20 PM
Junior Member
Default
The model # is 23022100
  #4 (permalink)
Old 09-13-2012, 08:54 AM
Expert
Default
Hi.
I suggest you to check the lid switch.Open the control panel and install temporary jumper between red and black wires of the switch.
The lid switch Part number: 3955735
If that not the problem check the timer contacts.Unplug the washer. Set the timer to Ultra clean drain pull out he knob. The following contacts should be closed: BKW-GY, WBK-Y, OR-R, OR-T, BU-BUO, WBK-WOR.
The timer Part number: 3955734
Post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Washer Forester Washer Repair 1 07-28-2011 10:08 AM
Kenmore Elite He3 Washer proxybox Washer Repair 0 07-20-2011 09:51 AM
Kenmore Elite HE3 washer seafie Washer Repair 1 07-17-2011 05:14 PM
kenmore elite washer jowash Dishwasher Repair 0 03-06-2011 11:27 AM
Kenmore Elite Washer skifrk Washer Repair 1 03-22-2008 06:03 AM
