| » Whirlpool washer model GHW9150PW1 |
Model Number: GHW9150PW1 Brand: Whirlpool Age: Less than 1 year
I would like to know what voltage comes from the motor controller to the motor? Is it a DC voltage or AC voltage? I have checked the continuity of the motor and I get 6.2 ohms between each of the 3 legs and the motor turns free without the belt installed. I am getting a failure code F06 which means the motor tach is not signaling the control of sufficient speed. Is there a test procedure available for tis machine?
Thanks Dave Ads By Google Related Models |
Measure the resistance between the pins 4 & 5 at the motor. If the reading is about 120 Ohms, replace the MCU. If the reading is incorrect, replace the motor.
- The MCU Part number: 8182706 - The motor Part number: 8182793 Here are the breakdown diagrams and Replacement parts for Whirlpool GHW9150PW1 AUTOMATIC WASHER | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The resistance at the motor is 6.2 ohms on each of the three connections. This nearly exactly what the company said it needs to be.
What I need to know is what voltage is applied to the motor at various speeds. I feel like the motor controler is at fault. I have been told that there is a sheet inside the washer with instructions for trouble shooting the washer. I found where it was but it is gone. Where can I get another one of the sheets. Dave |
Quote:
I did read it in your first post. There are five pins at the motor plug. You did measure resistance between the first three of them and I asked you to do the same test for the pins 4 & 5. Can you do it please? Gene.
__________________
I would recommend to replace the MCU board in such situation. The part number I posted earlier.
__________________
| Display Modes | |
| Kemore Washer Model (made by Whirlpool) | D.I.M. | Washer Repair | 1 | 07-12-2011 06:31 PM |
| Whirlpool Washer Model LA7780XSN2 Stock LA7780S - Agitator Problem | tossingc | Washer Repair | 1 | 06-28-2010 11:10 AM |
| F11 code on GHW9150PW1 | chrisroth | Washer Repair | 0 | 06-12-2010 02:29 PM |
| Whirlpool Washer - Does not advance to spin cycle - Model No. LSQ9549PW | wenkyon | Washer Repair | 1 | 04-14-2010 01:25 PM |
| whirlpool washer model number | jkat1 | Washer Repair | 2 | 02-12-2009 11:11 AM |
